Install fo IZZE-Racing Air Pump simulator
Install of IZZE-Racing Air Pump simulator
Installing this later today... want to double-check about taping into the ECU wires. What kind of tap should I use? Is a splice connector the right way to do this?
Thx!
Thx!
I cut the wire in half so that you can put shrink wrap over the modification.
the wires are small, so the work is a bit tedious.
The standard for automotive wiring is crimping. Soldering is okay for low vibration environments with good strain relief.
Squeeze / vampire connectors should never be used. They are notorious for causing intermittent and incomplete connections.
If you have any questions, send us an email (support at izzeracing dot com) or give us a call (number listed on our website).
Caleb
Caleb
How long does it take for the monitors to reset i just installed mine and did 2-5min cold starts but my rediness monitors wont reset i drove it about 5 miles after the reset no CEL tho
I removed each plug from it's plastic connection that way you can splice a 1/4" piece off of coating, solder the Izzie wire to this then you can slip shrink wrap over the connection and reinsert. I guess it's the same as above your just not cutting the OEM wire. Little more work but it looks cleaner (not that you see it) "OCD" . I always use shrink wrap instead of electrical tape.
