Invidia N1 rubbing against axle?
So I had found a steal online for a used dual Invidia N1, for $60 and only needing gaskets I couldn't pass up the offer. It took me maybe an hour or so to install in the garage this morning but I can't seem to get it to sit right. For starters, the mid pipe rubs against the axles (I have DriveShaft Shop 2.9 Axles and a 70mm Invidia test pipe). I have the mufflers installed and they both seem to stand out away from the holes in the bumper, towards the sides of the car. The mufflers being out of alignment I can mess with and fix, but the mid pipe still rubs up against the axles. I tried to loosen the bolts at the test pipe and so on to move it over as much as possible but it doesn't budge, just goes right back to rubbing up against the axle while driving. I've read a few threads about fitment issues, but never with the axles being a problem. Any advice here? Any way to sort of move the exhaust away from the axle? The OEM system didn't hit anything so it kinda worries me. Thanks in advanced. I can post photos in the morning when it's light out.
So a torch, a vice grip, and a lot of swearing later it doesn't rub. Never have I ever had this much trouble with an exhaust, at least it doesn't sound half bad I guess. All the hangers needed pulled up and out to let the whole system hang lower, one I even re-welded to sit a little farther to one side.
I didn't hear any clunking or knocking from this, it was more of a lower pitch metal to metal grinding sound that I could only hear at lower speeds or when I was coasting in neutral. If you're hearing a clunking or knocking in first gear I would personally look in to suspension parts, mainly bushings, to see if anything is torn. It could just be impeccable timing.
steven88
05-13-2016 12:56 PM
