RSG Carbon OEM Hardtop front air leak
So my friend's car has a Rockstar Garage OEM Carbon Fiber Hardtop. At *higher* highway speeds the from of the hard lop will i guess flex a bit and you can see air leaking in front the middle extending towards the edge.
We are using factory hardtop strikes and latches in the front and the aftermarket brackets in the rear
Using a latch spacer won't do any good I don't believe because it's sealed when it's not moving. I'm thinking of suing a flat piece of weather stripping. Has anyone done this or come across this issue?
Id try using aftermarket brackets in the front. You can try re-seating the hardtop on the car, It could be on slightly to a side with catchers or shifting at speed. I used these and it worked well. (RSG version)
