Spring and Retainers Upgrade Options
Alright, Ive searched for aftermarket valvetrain upgrades and only came up with a few older threads on this topic.
I want to make an informative thread on these options as i had some trouble finding enough info to make a comfortable decision; and input from any experienced owners would be great.
This page from 4piston was very helpful.
http://4piston.startlogic.com/valves...pringsEVO.html
I have a 2008 ap2 running stock cams and was only interested in upgrading springs and retainers at this time to maintain high revs and increased safety. As you guys all know, our options boil down to single spring vs dual spring among different manufacturers.
PSI single springs seem to be the ideal pick being itll provide the lowest harmonics due to its innate single spring design. And theyre so robust itll allow up to 11k rpm durability (according to 4piston). This is a nice cushion for overevs. Downside is highest price. And if spring fails, no secondary spring to prevent the valve from dropping and completely ruining head and block.
Similar options: Ferrea beehive and Supertech beehive
Supertech dual springs seem to be the most practical option as its cheap and has been proven by many users. For most of us (who daily drive), these are probably safe to go with since itll provide increased rev to 9.5k cushion.
Is this fair to assume? Im leaning towards supertech duals for now (mainly due to value) but was curious as to longevity and characterisitcs of them for daily use. Im not a prostock racer or crazy drag/track racer thatll abuse them to the point of needing a replacement every 5-10 runs. I daily my s2000 and go on spirited drives and local tracks once-twice per year.
Also are there any maintenance required with springs/retainers? Do they require break-in or valve adjustments or routine replacement after some time/mileage?
I should mention that im boosted (turbocharged) as this would probably alter suggestions to upgrading the valvetrain.
As far as springs go a good fresh set of OEM would be my pick.
As well as guides n retainers if ur driving it like u say.
valve metallurgy and brand is what I would not skip on for function. Things that like or control heat better and weight will help.
Sorry i didnt mention it being boosted. Im a huge believer of oem for factory or near factory setups. But for boosted applications with increased rpm speed and repetitive hitting of redline, 2step, etc, dont we need something stronger than oem? I was hoping to gather some info from owners who have successful and/or unsuccessful use of aftermarket springs/retainers both in short and long term conditions.
4 Piston Racing::Valve Springs
I should mention that im boosted as this would probably alter suggestions to upgrading the valvetrain.
upgrade. If u r , go with supertech dual spring with titanium retainer and seat. The best !
Those single psi springs probably up the closed and open pressure a bunch.
and if a spring breaks on a dual I doubt the smaller one would actually save anything.
I just try not to re engineer something that was designed by Honda's A Team.
If u have stock redline and stock cams, I would stick with OEM springs.
valve material and seat material especially on the Exhaust Side will be the money maker.
Most stock Honda valves will actually flow better than aftermarket because of the bowl they have on the bottom, but ur FI so that doesn't factor as much.
I have a fully built H22 with an entire skunk2 pro series valve train, cams, everything.
I'm just saying, I would go for a wicked valve made for fi, the beryllium seats might be overkill, but will help with heat for things like 2 step for ex.
And an awesome seat cut to compliment everything.
Thanks for your input guys. Im only looking to upgrade springs and retainers at the moment. My dilemma is choosing between the supertech duals (cheaper) vs psi single (seems to be the better option but not sure if its worth the $400-500 higher price). Ive rarely heard of supertech duals failing except for in cases when aftermarket cams were used and improperly paired with the wrong springs for clearance. Sooo...yea...torn between the two options and was hoping you guys would convince me one way or the other.
I had the same probleem choosing ferrea or supertech. I went for ferrea... Little bit more expensive, but they guarantee you a new engine if you blow yours due to their failing product.
Really nice stuff
Really nice stuff
