Exhaust drone - anybody ever welding in that
So, I just deleted my previous topic since nobody was staying on topic.
Here's the question.....
Has anybody ever tried welding in that "T-pipe" that is on the OEM exhaust to reduce drone if you have an aftermarket exhaust.
Please don't tell me your exhaust doesn't drone, that's not what I'm asking...thanks everyone!
That "t pipe" is a branch resonator and its engineered to work with the stock catalyst.
So when you spend the money to buy a spoon or asm catback with the branch resonator after the cat and you are using a testpipe, then you're defeating the purpose and the drone cancelling properties.
Most people who have aftermarket exhausts usually have hfcs or testpipes too.
If you're using the stock cat it might work. I believe testpipe setups drone the least in exhaust systems without the branch resonator and hfc are the worst.
Some exhausts for example the evs ssp70 are 70mm replicas of the asm siren circuit without the front branch resonator and a modified one near the muffler are designed to work with a testpipe rather than a cat.
Sent from my T-Mobile G2 using Tapatalk 2
So, if my skunk2 has it's own resonator, and I have a test pipe, what would be the likely effect of the branch resonator if I welded it in?
That branch/helmholtz/donkey dong resonator affects a fairly narrow sound frequency range. You'll probably not reduce drone enough to make an annoying exhaust livable. I used a section of OEM midpipe (triangle flange to Y split) on my Toda 60mm cat-back and it reduced overall loudness slightly, more a function of the larger midpipe resonator IMO. It still droned although the tone seemed to have less "attack", kinda hard to explain but the sound was more of a "whoosh" instead of a "bark". Bottom line; sound tuning is a complicated and expensive endeavor, buy a Fujitsubo/Mugen/Tanabe for a sporty but mature sound.
The OEM resonator doesn't reduce power, but it does reduce midrange torque when you tune for a lower VTEC engagement.
You can achieve some reduction in drone with a properly sized branch duct (J Pipe), but it isn't as effective as a properly designed mid-pipe.
Here were a few J Pipes I tried out. They had to be about 30 inches long in order to attenuate drone at 3500 RPMs. As someone mentioned above, they aren't effective across a wide frequency range, and the drone frequency changes with temperature.
Chugs
12-11-2015 06:35 PM
the s2k dude
10-12-2010 11:58 AM
