***Official Gears Thread***
#22
Here's another thread on AP2 transmission into AP1 swap, with good info on parts required and whatnot.
https://www.s2ki.com/forums/index.php?showt...0&#entry7902924
#23
Former Sponsor
If you buy a used differential with gears in it you don't need to break it in as it has already been broken in. Won't know how it was broken in but will have already been through the heat cycle break in process.
#25
Former Sponsor
Yesh you wouldn't have to. When breaking in fests you are heat cycling the actual gears so since they are used shouldn't need to break them in at all.
#26
Originally Posted by Back S2k,Feb 10 2009, 09:38 AM
If I buy a used gear set do I still have to break it in??
A freshly built rear using used gears will still need a short break in to seat the bearings and run in the newly set gears. A heat cycle is not necessary but, no hard driving should be done for 200 to 300 miles.
The oil should be changed after 500 for inspection.
#30
Originally Posted by S2KPUDDYDAD,Feb 12 2009, 07:10 AM
Even with used gears, it is best to do a short break in.
