S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
64mm ITB and 17" intake runners
Old 01-14-2017, 08:45 AM
s2000ellier's Avatar
Default 64mm ITB and 17" intake runners
Will it make power below 8000 rpm?
Old 01-14-2017, 12:38 PM
Sylvain2000's Avatar
Old 01-14-2017, 07:30 PM
s2000Junky's Avatar
Try it and find out, if it doesn't then cut them down incrementally until they provide the powerband your looking for. Looks like you need an Allen wrench, a tape measure, marking pen, cut off wheel and a dyno.
Looks like someone already went to the trouble to weld on extensions to the horns. What was the previous application?
Old 01-15-2017, 04:49 AM
they came off a midget sprint car
Old 01-15-2017, 05:15 AM
All pretty affordable beside the dyno !!!
Old 01-15-2017, 07:09 AM
had to trim 1.5" off to clear the brake MC and booster
also ordered some 1" hood risers in hopes of not having to cut the hood
Old 01-15-2017, 07:27 AM
flanders's Avatar
Wow that looks pretty crazy but I like it
Hope you get it to fit with the hood closed, might need to cut some of the inside frame though.
Old 01-15-2017, 08:47 AM
hoping these hood spacers i bought will let it clear otherwise, time to chop it up!
Old 01-15-2017, 04:48 PM
From the pictures they look like they are 3" higher than the valve cover !!
Good luck with the grinder 😜
Old 01-15-2017, 07:27 PM
s2000Junky's Avatar
Cut it and put in some kind of sleek looking scoop for the horns. Will be totally functional, just make sure your considering rain.
Quick Reply: 64mm ITB and 17" intake runners
