75mm testpipe availability? - S2KI Honda S2000 Forums
LinkBack Thread Tools
Old 06-18-2011, 01:31 PM   #1
Default 75mm testpipe availability?
are there any companies which made 75mm testpipes? ive searched ebay an didnt have any luck. i dont want to but a 70mm on which would create gas flow turbulence. regular 3" flanges arent shaped the same as the flange on the end of a testpipe so does anyone make/ or can make a 75mm testpipe? thank you very much for any info you may be able to helop me with!!!!
08s2000CRbackinblack is offline   Reply With Quote
Old 06-18-2011, 01:37 PM   #2
Search "Asura" on this forum... They should carry it ... If not be able to make one for you.
Luis06s2k is offline   Reply With Quote
Old 06-18-2011, 01:57 PM   #3
Member
slowd16's Avatar
Just find an exhaust shop local to make one.
slowd16 is offline   Reply With Quote
Old 06-18-2011, 02:21 PM   #4
yes i just found a post the asura can make one. i have plenty of 3" flanges but none the match the shape of the flange used to bolt up to the stock cat as this sytem was designed to. many exhaust shops dont use SS either. i wonder how much asura charges for their testpipe? im suprised more companies are making these like invidia
Old 06-18-2011, 07:21 PM   #5
whiteflash's Avatar
Asura
whiteflash is offline   Reply With Quote
Old 06-19-2011, 05:49 AM   #6
Member
slo ap2's Avatar
ultimate racing also makes a 3in. testpipe too. That's what I'm running now.
slo ap2 is offline   Reply With Quote
Old 06-19-2011, 08:05 PM   #7
I originally ran a UR 3" test-pipe with my HKS 75mm and it didn't fit worth crap. I ended up going with a Hytech 3" test-pipe through GTmotoring(designed to bolt to an OEM like header).
H22toF20 is offline   Reply With Quote
Old 06-19-2011, 10:21 PM   #8
Member
slo ap2's Avatar
suppose they are hit or miss then. I don't have any issues with mine.
Old 06-20-2011, 12:26 PM   #9
Originally Posted by H22toF20' timestamp='1308539147' post='20699175
[quote name='slo ap2' timestamp='1308487796' post='20697600']
[/quote]
The angle it mounted to the OEM manifold was VERY bad. I actually did run it for 3 months with zero leaks though. Once it started leaking I opted for the Hytech. I didn't even try selling the UR, I just scrapped it.
Old 06-20-2011, 05:53 PM   #10
i just orderded the UR and they are special making it to my order so hopefully it will fit perftect, if not i will modify it to fit perfectally. asura said they dont make they testpipe and only the resopnated version =( i will be receiving the UR testpipe wednesday so i will let you know how it goes. thanks giuys!!!!
Thread Thread Starter Forum Replies Last Post
Where to buy NSX/OEM rear calipers Szoylent Green S2000 Brakes and Suspension 10 01-11-2017 07:23 PM
2017 w/ NASA NE freq Delaware Valley S2000 Members 5 01-09-2017 07:05 AM
TX: 2005 Silverstone - 89,000 - Hardtop Kuro! Cars for Sale 8 12-05-2016 02:05 PM
VA: FS: Rear upper control arms for AP2 maengelito R&C Parts For Sale 0 11-22-2016 01:09 PM
HKS Hi Power Exhaust Single Exit *New in Box* Scracho Southern Ontario For Sale 0 11-17-2016 04:54 AM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
