Aftermarket cams reliability
After reading dozens of threads on either BC cams or skunk2 cams, there were too many mixed results on if they made power or not. Putting aside the fact that if aftermarket cams do make power or not, are they reliable? I did not want to go this route initially but I have ran out of bolt on mods that I can possibly do, excluding the skunk2 manifold that finally got released today. I have heard stories of issues with rocker arm clearance, loud noises, and an increase of aluminum in oil after sending to the lab to analyze the oil.
So my question is, are aftermarket cams reliable for the car, or will they reduce the longevity of the motor? I have a set of bc stage 2 cams sitting around and not 100 percent sure on installing them yet. Any input will be greatly appreciated.
the cams do make power. Skunk2 and BC stage 2.
My bud who tracks his car a lot had some materials show up in his oil reports from BCs. Once he removed them the wear was gone but he did make close to 15-20whp IIRC.
I have Skunk2 to install soon. These made 15WHP recently on my other buds track car about 2 weeks ago.
More important, where is this Skunk2 manifold being released info!!!??? lol
Cams installed less than 2 years, Track only car so no real daily. Couldn't have been more than 6000 total miles. Was getting aluminum in my oil analysis. Found where it was coming from.
^^ Thats the guy I was taking about....good morning bro!!
more research hhahahaha wait till later after I text you guys 30 milion times on finding lmao
But really, do stiff springs cause more wear?
My car is a 06 ap2, and it is not my daily but i do drive it often. I would like the car to go for 100k miles with the cams in it if it's possible.
Wow. did you remove the cams after you saw that? Do you think the wear would continue or would it stay like that?
I removed the cams from my oil analysis telling me something was wrong. The cams were the only thing I changed. Since it was aluminum in the oil I went to the head first and these are what I found. Most can catch a finger nail on the grooves.
My buddy has had a theory that I don't agree with but I'll put it up. He thinks the supertech dual springs were the cause since they have more pressure than stock or even the beehives. I call bologna but it's out of my expertise.
My theory is the cam oil journals weren't perfectly round or the tolerances were greater than stock.
