S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
best fitting test pipe?
Old 03-12-2017, 10:07 PM
S2000_916's Avatar
Default best fitting test pipe?
my buddy just purchased a berk 63.5 mm test pipe. he is having fitment issues, saying the pipe does not have the proper angle and is too short. is there a old version of a berk test pipe vs 2.0? I am also in the market for a test pipe and don't want to deal with the hassle of a product that doesn't fit proper. what is the best fitting test pipe? for stock exhaust
Old 03-13-2017, 04:13 PM
cleenyc99's Avatar
toda makes the best tp that I no of, personally I run an invidia it fits grate. I've had it for years and hasn't rusted so I'm happy with it
Old 03-13-2017, 05:50 PM
fernando.'s Avatar
Weird, my Berk fits just fine.
Old 03-13-2017, 08:58 PM
Jae2K's Avatar
yeah, my berk fits really well too
Old 03-13-2017, 09:09 PM
S2000_916's Avatar
have you seen a toda in person? can you tell a quality difference? what mm invidia?
S2000_916's Avatar
what size? when did you buy?from who?
Old 03-13-2017, 09:38 PM
shins's Avatar
its probably the gasket thats causing the problem
Old 03-14-2017, 09:23 AM
fernando.'s Avatar
I don't even remember who I bought it from, it's been years. Mine is 63mm.
Old 03-14-2017, 11:45 AM
Kirk180's Avatar
Huh? I have a Berk and thought they were typically higly recommended. Not to say he's overlooking something, or has his exhaust hung wrong, but is there a chance something isn't installed right?
Old 03-14-2017, 12:43 PM
Memo6453's Avatar
Berk fits fine. not sure what your issue is, maybe post a picture? i use invidia since it was the only true 60mm test pipe. Although the 63.5mm works fine as well. Id go with any that are available from Berk, Invidia, or the like... If Toda has a test pipe, i can almost assure you its gonna be 3 times as much as the others stated, and don't see the advantage... also, unless you have a 06+ model with a flashpro, theres not much to be gained without some sort of tune... 00-05 would need some sort of eng. mgmt to extract the benefits of the TP.
Quick Reply: best fitting test pipe?
