CNC Speedshop 2.4 liter stroker kit installed but making LESS power than before
#21
If the AFR's are correct on that dyno your crazy lean up top. Like don't drive it your gonna melt a piston lean. Either the AFR's are off on the dyno (entirely possible) or your tuner isn't doing his job.
But that doesn't explain why your TQ curve is a near overlay at the lower RPMs. You should have a change there.
#22
#23
#24
#25
#26
#28
#30
I see the pictures and I think notching to the cylinders has been done but was it to the necessary extent I cannot be sure. May be my best step from now on will be to take a look inside the engine and check for any mechanical problems. What do you guys think?
