f20c with k24 crank(f24 stroker)
#21
Banned
its not a big deal to remove them.. people have been plugging oil squirters for many years on other honda motors with no problems. Most engines dont use them from the factory
#23
All that needs to be done is to have the lip for the flywheel machined away. I believe there are only two different part numbers for the K24 cranks. All K24 motors use a single part number except for the first generation TSX's. Even the older TSX's changed to the same part number as the Element and such.
#28
I am also interested in stroking my s2000 to 2.4 liter.
#29
#30
To match the piston speed of the 84mm crank at 9k, the 90.7mm crank would need to be capped at 8375rpm (which is why Honda reduced the redline to 8k - to give a safety margin). The 99mm crank only needs to be doing 7,673rpm to match the piston speeds of the 84mm crank at 9k.....
This is what happens to even tuner prepped cars if they are revved too high :
https://www.youtube.com/watch?v=eWUPcvF6hC4
Obviously Honda have built in some safety margin with the standard limit of the 84mm crank, but I wouldn't be wanting to be going much beyond a piston speed of 84pfs without some significantly stronger rods / rod bolts.
