Skunk2 intake manifold
#211
So are you saying a simple spacer like they used on the K series to mount it to a s2000 (adapter plate) adds the 2" necessary to show the nice gains CNC saw? maybe they should just make a plate of different thicknesses so you can tune the powerband.
To be honest all of this seems like conjecture...we need a dyno with the F series skunk2 ultra manifold...
The injectors are very specifically angled directly at the intake valves. basically what this does is the fuel in injected parallel with the air flow as its turning the bend into the cylinder.
If you put a spacer between the head and manifold, the injectors now point towards the opposite side of the intake tube, so when the injector fires, the fuel is sprayed on the wall of the intake tube. Same idea as if you take a spray can and spray directly on a surface. The fuel will pool and turn back to liquid as soon as it hits the wall.
Now, if the intake was a two piece type, then you could put a spacer between the tubes and plenum, which would work well.
Anyways, I've scanned the factory intake and made a model of it SolidWorks and played around with the geometry, and ran a number of fluid dynamics simulations on it. The best results I get flow wise is if the plenum volume is increased by about 30%. So, my plan is to modify an existing S2000 intake by sawing half the plenum off, welding extension tubes to the intake runners and welding in a plenum spacer. It certainly would have been a lot easier if someone like Skunk2 actually made a practical street intake. I'm completely swamped with work stuff, so I have no idea when I'll be able to get around to hacking on this intake.
Szoylent Green (12-08-2016)
#213
#214
[Q
UOTE=s2000ellier;24117053]cut oem and weld this on End feed plenum - Nissan Q45 throttle body - K Series - Honda[/QUOTE]
. I MIGHT TRY THIS IT'S CHEAP AND I JUST BOUGHT AN EXTRA INTAKE MANIFOLD JUST TO INSPECT THE DESIGN THANKS FOR THE SHARE
#216
#217
#219
Hmm he gave me a price and acted like it could be in a box that day. Yes it was a 1 off. It was made to match the specs of my K series one for a buddies F24.
#220
By the way, why extend the runners apart from increasing the plenum size? You found that more runner length has the potential for more power in the simulations?
