S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
Toda Spec C Cams
Old 07-20-2016, 02:42 PM
Ham8urger's Avatar
Default Toda Spec C Cams
Has anyone used these Toda Spec C Cams? Anyone have dyno sheets? Pro's/con's? I can't seem to find any reviews or dyno for them. All of the specs fit the bill for some great cams... I just want to get info on results
I got an incredible deal on brand new Toda Spec C camshafts, Toda Valve Springs and Toda Cam Gears. I also have the the Toda Torquie Kun header.
Old 07-20-2016, 02:48 PM
Ham8urger's Avatar
Here are some pics of the Toda Torquie-Kun header just because it's beautiful
Chibo (11-08-2019)
Old 07-21-2016, 08:01 PM
JDMpearlwhyteZ's Avatar
Are these the vtec killer cams?
Old 07-22-2016, 02:19 AM
flanders's Avatar
No, you can clearly see it still got three cam lobes on each valve pair
Old 07-22-2016, 09:35 AM
S2kAndTheAnt's Avatar
I have the Spec A cams, definitely makes my car sound more agressive.... Don't forget to clearance your rocker followers on the EX side.
Old 07-23-2016, 08:11 AM
Sponsor
Urge's Avatar
Originally Posted by freezingcoffee
I have the Spec A cams, definitely makes my car sound more agressive.... Don't forget to clearance your rocker followers.
Just need to clearance the EX rockers..
__________________
Old 07-23-2016, 06:49 PM
Requiem's Avatar
Curious as to what a dyno looks like with the cams
Old 07-25-2016, 06:46 AM
AngryTurtle's Avatar
I dont think dynos have cams.
Old 07-30-2016, 06:59 AM
jst2878's Avatar
Lmao
Old 07-30-2016, 02:48 PM
Ham8urger's Avatar
I won't have a stock baseline but I can post my dyno graph when done.
Mod list:
Haltech Pro Plug In
Toda Spec C's
Toda Springs
Toda Torquie Kun Header
AEM V2
Still deciding on which 70mm exhaust to get
And still deciding if it will be better to run a normal 70mm TP or if I should get the Toda 60mm to 70mm transitioning TP shown below...since the collector on the header is 60mm
Quick Reply: Toda Spec C Cams
