2014 Megan Racing S2k Challenge Rules and Schedule
Old 01-26-2014, 05:56 PM
psychoazn's Avatar
Default 2014 Megan Racing S2k Challenge Rules and Schedule
2014 Megan Racing S2K Challenge Series Rules
MODIFICATIONS
Aerodynamics
0.25 = Level 1 Front Aero: aftermarket front bumper or any aftermarket or CR lip (must not have splitter built-in)
0.50 = Level 2 Front Aero: full front aero package (anything more than a simple lip or bumper; can include any spats and canards)
0.125 = Canard Set (each set L/R, if not combined with L2 Front Aero)
0.125 = Spats only (each set L/R, if not combined with L2 Front Aero)
0.25 = Level 1 Rear Aero: rear diffuser
0.50 = Level 2 Rear Aero: full underbody tray with diffuser
0.125 = Vented hood
0.125 = Vented fender
0.125 = OEM-style hard-top (includes Mugen/Mugen replicas)
0.25 = Spoon-style hard-top
0.125 = Aftermarket or modified rear bumper
0.125 = Vortex generators
0.25 = Aftermarket rear spoiler or OEM rear wing
0.50 = Level 1 Wing: CR wing or smaller
1.50 = Level 2 Wing: APR GTC-200, Voltex 1S wing or smaller
1.75 = Level 3 Wing: Any adjustable wing bigger than APR GTC-200/Voltex 1S
2.00 = Level 4 Wing: Any multi-element wing or active wings
0.125 = Risers or wing mounts taller than default mounts (applies to Level 1-2 Wings)
0.125 = Gurney flap (applies to Level 1-2 Wings
Wheel and Tires
-1.00 = Any street tire TW 240+ (V12, T1R, DWS, etc.)
0.00 = Any street tire: TW 140-220 (RS3, Z2, AD08R, RE11A, 595RSR, etc)
1.25 = Level 1 R-compound tire : NT01, RA1, R888, A048, PSC, RC1
2.50 = Level 2 R-compound tire: R6, V700, R1
4.00 = Level 3 R-compound tire: V710, A6, C91
0.25 = 235 Front tire size
0.50 = 245 Front tire size
0.75 = 255 Front tire size
1.00 = 265+ Front tire size
0.25 = 265+ Rear tire size
0.00 = OEM wheels in original staggered configuration
0.25 = Wheel spacers on OEM staggered wheels
0.25-0.75 = Aftermarket wheels. See table below for penalty for wheels. The combinations in gray are not allowed. Wheels larger than 10" wide are not allowed.
Power and Engine
0.00 = OEM AP2 2.2L Engine
0.125 = Any aftermarket non-ram-air intake system or modification to OEM intake (includes cooling plate)
0.25 = Any aftermarket intake system that utilizes a snorkel or ram-air effect
0.125 = Any aftermarket header
0.25 = Test-pipe
0.125 = High-flow catalytic converter
0.125 = Cat-back exhaust
1.00 = Internal Engine Modifications (see below for exceptions)
0.50 = Aftermarket Camshafts
2.50 = Forced Induction (Limited to 400whp on DynaPack), must take separate penalties for ECU, intake, and header as applicable
0.25 = Aftermarket ECU, ECU reflash, or OEM ECU mismatch (example: AP2 motor with AP1 ECU)
Suspension
0.50 = OEM CR suspension
0.50 = Aftermarket spring up to 450 lbs/in with OEM non-CR shocks
1.00 = Aftermarket spring up to 500 lbs/in with any off the shelf non-adjustable shock or CR shocks
1.00 = Full coilover suspension with 1 way adjustment (e.g. Megan, BC Racing, Stance, Ohlins DFW, HKS Hipermax III, etc.)
1.25 = KW V3 or Clubsport
1.50 = All adjustable dampers/coilovers Full coilover suspension up to $3500 MSRP with two or more way adjustments (e.g. SRC, Eibach R2, etc.)
2.00 = Full coilover suspension above $3500 MSRP (e.g. Moton, JRZ, etc.)
Drivetrain
0.25 = Non-OEM LSD
0.00 = Non-OEM Final Drive
Safety
We strongly encourage the use of a roll-bar, FIA-approved 5-point harness and bucket-seat (now abbreviated R/H/S). Refer to track organization minimum safety requirements.
Free Modifications
- any lightweight parts that do not also enhance performance by improving power, aerodynamics, handling, etc.*
- any interior removal as long as it does not compromise safety*
- any alignment, camber kit, bump steer kit, tie rod end, roll center adjuster
- any bolt-on chassis braces
- updating or backdating OEM parts except CR performance-enhancing parts*
- aftermarket steering wheel: only if R/H/S are installed for driver (otherwise prohibited)
- passenger airbag removal: only if passenger seat is removed, or R/H/S are installed for passenger (otherwise prohibited)
- aftermarket brake systems, brake ducts
- any OEM or aftermarket sway bars
- any spacer on aftermarket wheels
- AP1/AP2 OEM front and OEM rear spoiler (if you believe your aftermarket lip is cosmetic only, you must receive prior approval from the S2KC Committee*)
- APR lips and APR front bumper not longer free modifications
- aftermarket flywheel, clutch, pressure-plate
- gutting of OEM airbox, any aftermarket intake filter
- upgraded valve-springs and retainers
- oil-catch can, oil baffle pan
- up to 50-pounds of ballast weight for AP1 chassis cars, which must be securely bolted in the passenger compartment. If the passenger seat must be removed to accomplish this, up to 85 pounds of ballast weight may be used.
* If you are unsure whether your modification violates these rules, you must talk to a member of the S2000 Challenge Committee and receive prior approval before using these modifications. If you are found to be in violation after the fact, you will be disqualified from the event.
Absolutely Prohibited
- nitrous oxide systems
- E85 gasoline, leaded gasoline, anything higher than 100 octane gasoline
- removal of vital safety equipment such as bumper beams, roll-hoops or airbags without R/H/S, etc.
- ballast weights on an AP2 chassis
S2000 CHALLENGE CLASSES
Stock Class - 0.5 points maximum
The purpose of this class is to keep costs down and be attractive to a newcomer with a completely stock S2000. Drivers of all experience levels are welcome. Tires are restricted to TW 140+ and no larger than 235/40/17 front and no larger than 255/40/17 rear.
Certain modifications are not allowed in Stock class:
- No Level 2 Front Aero
- No Level 1+ Rear Aero
- No Level 1+ Rear Wing
- No light-weight aftermarket parts, no aftermarket body panels, or any interior removal (unless necessary for safety equipment). If a Stock Class driver opts to install a hard-top and remove the soft-top and associated hardware, he must retain the spare tire to make up the weight discrepancy.
Street Class - 3.5 points maximum
The purpose of this class is to allow moderate modifications to a primarily street-driven car, as well as allowing CR owners the ability to truly "arrive and drive." Minimum weight for Street class is 2850 pounds with driver. Level 1 R-Compound Tires are allowed in this class.
Certain modifications are not allowed in Street class:
- No Forced Induction
- No Level 2 or 3 R-compound Tires
Modified – 6.5 points maximum
Minimum weight for Modified Class is 2800 pounds with driver.
Super Modified - 9 points maximum
Minimum weight for Super Modified Class is 2700 pounds with driver. Participants of this class may use any ballast weights in any chassis (AP1 or AP2).
Novice Program
This class is designed for newcomers to the S2K Challenge. Novice Program drivers will be assigned an S2KC instructor for the day, to provide guidance and support. Novices will still compete in their respective classes, and score appropriate points within that class. There will be a separate competition among Novice Program participants, which will be based on a PAX system, where 1 point is equivalent to a 0.5 second penalty. To be eligible:
- One must have attended fewer than 3 S2KC events*
- One must run in beginner or low-intermediate group
- May not have any modification that result in automatic Unlimited classification, but may have points exceeding Modified-R Class limits.
***First time S2k Challenge/Speed Ventures drivers get 50% off of their first event!***
2014 Speed Ventures S2k Challenge Advisory Board
Mike Tsay (dipstick)
Mike Kang (psychoazn)
Dustin Dessero (ddess)
Joseph Jaffrey (JJ1)
WEIGHING
Rules
Each class has a minimum weight: at any point during the day, a competitor with driver inside must meet that minimum weight. If and when a competitor is found to be below minimum weight, he will be penalized 1 second for every 25 pounds he is under the minimum weight. If this is the competitor’s first violation, the first 25 pounds will be allowed as leeway (for possible scale-to-scale variation), but he will be penalized for any further discrepancy. Also, if this is the first violation, he may choose to forfeit all laptimes he has accrued until the weighing process, add back weight to his car to meet minimum weight, and re-start new timed laps instead of taking a lap-time penalty. Any repeat violations will automatically incur the lap time plenty as outlined above.
Weighing Protocol
One competitor from each group (Street and Modified) will be selected at random to be weighed at any time during the day. The probability of being weighed is directly proportional to the number of points he has accrued throughout the season (for example, this is equivalent to adding one’s name in a hat once for every point he scores, then drawing from that hat at random). That means top drivers have the highest likelihood of being weighed, and drivers who have yet to score points will never be weighed.
Weighing Logistics
Two drivers from each class may volunteer or will be randomly selected to participate in the weighing process. Only drivers from a different class may weigh one class (to create impartiality). For example, if a Stock class participant is being weighed, only the two drivers from Street and two drivers from Modified may assist in the weighing process. All who participate in the S2KC implicitly agree to help with the weighing process if called upon, barring any extenuating circumstances.
PROTEST PROTOCOL
A competitor may also be spot-weighed if three peers (or at least half of the participants of that day, whichever is less) from the same class believe the competitor to be in violation of minimum weight. That competitor will be liable to be weighed on the spot. In addition, if a competitor suspects another is underrepresenting his points, he may bring his concern to a member of the S2KC Committee immediately, so that a committee member can audit the car at that point, and compare the setup to that declared on the signup sheet. If a participant fails the audit, he can choose to: 1) correct the violation and forfeit all a previous laps and redo timed laps for any remaining sessions; or 2) take a 1 second penalty for every 0.25 points he is over the limit.
Prizes
Prizes at individual events for each class will be awarded regardless of number of competitors in the class.
Year end prize winners need to have participated in atleast 6 events.
2014 S2K Challenge Series Season
1 January 26 - Buttonwillow (13CW)
2 February 16 - Auto Club Speedway
3 March 22 - Chuckwalla (CW)
4 April 20 - Buttonwillow (13CW)
5 May 19 - Spring Mountain (not locked in yet)
6 June 29 - Willow Springs Road Course
7 July 18,29,20 -- MAZDA Raceway (92db)
8 August 10 - Auto Club Speedway
9 September 21 - Buttonwillow (CCW)
10 November 23 - Chuckwalla (CCW)
11 December 6 - STREETS
12th event TBD.
**Best 8 out of 12 events will count towards final championship points.
Old 01-26-2014, 05:58 PM
psychoazn's Avatar
Changes are in Red.
TL;DR version:
- Wheel table resolution increased to 1/8 point increments
- All coilovers and adjustable dampers are 1.5 points
- Level 2 wings are now 1.5 points; Gurney and Risers/High mounts are 0.125 each
- Level 3 winsg are now 1.75 points
- Level 4 wings added
- All wings allowed in street class
- Aftermarket cams are 0.5 points (still must take penalty for ECU/tune, etc.)
- Street class point cap reduced to 3.5 points (forces participants to choose 2 of 4: wing, coilovers, square tires, r-compounds)
- Mod class remains 6.5 points.
- SupermMod class point cap reduced to 9 points
- 240+ TW tires get a negative one (-1.00) point.
Old 01-26-2014, 07:57 PM
Sebring AP1's Avatar
Thanks guys!
Old 01-26-2014, 10:05 PM
Bullwings's Avatar
??? Typo? Wheels larger than 10" now allowed, right?
Also, no different levels of wings? So, keep it simple, either stock, CR, or bigger... Seems like GTC-200 is no longer the bargain it used to be, although it's probably the only wing that can be used without a front splitter.
Old 01-27-2014, 07:28 AM
psychoazn's Avatar
Ooops, yes that's a typo on the +. Wheels larger than 10" are allowed
Correct. However, we are also factoring in the fact that the GTC-200 was re-designed, and is more effective than before. Additionally, the 1S can be mounted very high, with a gurney flap and some angle, and make significantly more downforce than previously believed.
Old 01-27-2014, 07:59 AM
anorexicpoodle's Avatar
Wow it looks like ill only be at 4 events this year due to scheduling conflicts.
On the wing topic, I think Brians setup proved that the GTC-200 is not as different from the big wings as everyone thought.
Old 01-27-2014, 08:37 AM
Bullwings's Avatar
I thought Brian had the GTC-250...
I'm stuck with the "old" GTC-200, and do not plan to change it anytime soon. No big deal, there's a lot more driver time left to make up than their is in parts.
Old 01-27-2014, 09:37 AM
ringo14's Avatar
wow mod is 5.5 ... so if you want to run r comps in mod your nuts are chopped off with the changes to the gtc200.... i can see a .25 jump for that but .5 and the .5 change to coils is nut chopping
no square set up , wing and coils with r comps for mod ... seems drastic... everything seemed great until i saw that mod is 5.5 ,mod is basically street now lol
maybe mod should be 6-6.5 so the diff between mod and super mod isnt so huge and your mod car can still be tuned a bit... with the current changes and point drop a mod car is basically a current 4.5 car
255r
17x9
level 1 wing
r comps
hard top
coil overs
seems like a mod car to me, otherwise people will have to run cr wings in mod if they want to run nt01 or nittoz..... or super skinny front tires which wont make sense with a wing
Old 01-27-2014, 09:38 AM
You're all ricers
Old 01-27-2014, 09:51 AM
rhouck's Avatar
Splitter + wing + square + coilovers= 4.5 points
Add 0.5-0.75 for wheels (17x9 or 17x10) and you're basically done.
So no NT01/RC1 in Mod class unless you give up something pretty major. Looks like mod class will basically be a spec class
Edit: was typing before Ringer posted lol, similar thoughts. Should offer NT01/RC1 as 0 pt tire for Mod class?
Quick Reply: 2014 Megan Racing S2k Challenge Rules and Schedule
