Can an oil cooler effect oil pressure? Low(er) oil pressure issue
I posted this in the FI section (as that's where I normally hang out), but a fellow member suggested that I post up here for more info....
I recently switched my oil cooler setup. I ditched my Setrab oil cooler in favor of the Jackson Racing radiator/oil cooler combo, now I'm seeing lower oil pressure than before.
Cold start oil pressure is ~60psi
Warm idle pressure is 18-22psi
Both of those readings seem normal/good to me. Where I'm seeing a difference is cruising and under load oil pressure
Cruising oil pressure 60-75psi
Under load/Vtec crossover ~40psi
With the Setrab setup I was seeing 80-95psi cruising
So my big question is....can switching from a bar and plate cooler to a flow thru cooler lower my oil pressure?
On the plus side, my oil temps are staying lower/more consistant
Scott-
Scott-
Not surprising to see that result. Notice any difference in your coolant temps so far? Why did you switch from the Setrab setup?
My Setrab setup wasn't mounted in an ideal spot, so it wasn't getting much airflow over/thru it (so I was seeing higher oil temps than I was comfortable with). Instead of trying to build air ducts or mount fans on the Setrab unit, I decided to try the JR unit. My car is a weekend cruiser/show car, so keeping the engine compartment clean and uncluttered was a priority.
I haven't noticed much difference in coolant temps, but I did not have an issue with coolant temps prior to switching to the JR radiator (I was running a Koyo)
I'd also suggest sending an oil sample into blackstone. I had quite a bit more oil pressure then you've got and blackstone came back with a bunch of bearing material in the oil. Mine is a K series (but the oil systems are similar), and I was ~90psi at cold start, 50psi at hot idle and 90psi anything over 2k rpm.
You were seeing oil temps you weren't happy with on a street car..... What exactly were these oil temps you were seeing? Setrab makes a really nice cooler, I don't know what kinda core the JR unit uses, but if your getting an oil pressure drop over a setrab it would concern me a bit.
Yeah isn't 280F when most syn oils start to break down some? 200F is like the min heat you want just to safely run the motor through its paces. 235-250F would seem right in the middle of the good range. But I'm no oil expert.
