Can an oil cooler effect oil pressure? Low(er) oil pressure issue
#41
I use a mocal with the 200F option and on cold days driving to the track was seeing 130-140 temps measured at the pan, I fabbed a block off for my oil cooler to keep the oil warm on the street.
Tell me, do those of you who use the mocal with the 200F thermostat actually see 200F at the pan on the street?
I wonder if mine has always been faulty or stuck open?
Once I'm on track the temps climb to 210 to 230 by lap 3, as the pressure drops from 90 to 65 psi over 2k rpm.
#42
#43
Hmmm, that's a good point. I noticed my core was warm to the touch even after driving it very easy on a ~40 degree day. I've got a piece of cardboard ziptied to it now for driving in colder weather.
#44
#45
If you go to the dragon and hit the track 2-3 times a year, I highly recommend picking up an oil cooler with the thermostat. If you are boosted in anyway, I highly recommend you pick up an oil cooler with a thermostat.
If you never hit vattack and rub your S2 with a diaper, do not get an oil cooler at all.
I was cruising around my hood last weekend with watching my oil temps go beteeen 180-190 all evening long. Before I installed my oil cooler with the thermostat I would be in the 200-210 range.
I didn't have my oil temp gauge at the dragon last year, but I bet a dollar that my oil temps will be higher running through the dragon compared to a track.
Long story short, if you are anyway involved in spirited driving, buy an oil cooler. It's worth the 400 bucks for piece of mind.
S2K-F8
04-29-2017 06:47 PM
