Hardrace camber-adding (offset)/roll-center-adjusting ball joints for STR and track S2000s
Old 07-27-2011, 07:32 AM
  #21
//steve\\'s Avatar
How long have you been running them? You are autocross only right?
Old 07-27-2011, 12:35 PM
  #22
robinson's Avatar
I've had them on since the Spring Nats at Lincoln. Autocross only.
Old 07-27-2011, 12:56 PM
  #23
macr88's Avatar
James, where are you ordering from? Is it buyhardrace or somewhere else?
Old 07-27-2011, 05:10 PM
  #24
PilotSH's Avatar
Mac, since you're a mod, maybe you can tell me, I can post where I got it from, I just can't post the price? I'm unfamiliar with rules when it comes to possible "advertising" for companies. The only company in the US that distributes them is VelocityShop
Old 07-27-2011, 06:16 PM
  #25
macr88's Avatar
You can post it if someone that's not affiliated with the company asks otherwise you're not supposed to post it nilly willy.
Old 07-27-2011, 06:20 PM
  #26
macr88's Avatar
Oh and thanks for the link
Old 07-27-2011, 07:34 PM
  #27
robinson's Avatar
Old 07-27-2011, 09:42 PM
  #28
BowlofRice's Avatar
Ok I'll bite. How much were you able to get it for? From the other thread i think you said you got a better deal than the 275 price from velocity shop? Seems like eBay has it for 160 ish. Though I'm not if it is the 6621 model.
Old 07-27-2011, 11:51 PM
  #29
PilotSH's Avatar
Dave, thanks for posting the pic.
BowlofRice, the one you saw for 160ish is definitely NOT the same one as this one. They also have a ball joint that changes roll center only, and I believe that's the one you saw. The camber adding version is more expensive, and I don't see that one anywhere on ebay.
Old 07-28-2011, 03:55 AM
  #30
//steve\\'s Avatar
If all you want to do is change the roll center I think the smartest and cheapest thing to do is pull a stock one off and make a template and get a machine shop to make you a spacer and buy some quality hardware to replace the factory bolts. I bet you could have DIY roll center adjusters for under $50.
Quick Reply: Hardrace camber-adding (offset)/roll-center-adjusting ball joints for STR and track S2000s
