Here's My Valve Adjustment How-To
Rob, are you running "middle" spec or at the tight end?
There is an opening at the back side of the shield. You can work through that from the top and steady the wrench that way while turning it from above or it is a straight shot from below.
Just a note to make finding TDC easier. Pull your sparkplugs. Slid a long skinny screwdriver down the hole of each cylinder as you are searching for TDC. When the screwdriver reaches the top of its arc, you are there. Easy way to always find TDC on a cylinder. Been using that technique on bikes for many, many years.
If you look at cams they are mostly round and lobes are usually on one side. You can usually just see where it is
If the lobe is away from the valve you will be ok.
That's how I always done it and unless someone gives me another reason I don't see why it doesn't work
Makes it all muuuuch easier. A closed valve is a closed valve.
Every time I hear someone messed up their adjustment, it was due to losing track of timing marks and how much to turn engine. Use the lobe pointing method and you simply can't mess up this aspect.
This is a great how to, but it should probably updated to include a link to feeler gauges that have every size, not just the even ones. Makes it easier and you can be more precise if you have them all.
