Failure points of the S on the track
Old 05-12-2008, 10:10 PM
c32b's Avatar
Default Failure points of the S on the track
Hi, I'm interested to know what is likely to fail on the S with repeated track usage.
I'll start with areas I have heard to be weak.
1. Rear Brake hub (due to heat buildup from solid disc setup?)
Rear Hub Replacement
https://www.s2ki.com/forums/index.php?showtopic=223599
2. Suspension Arms (A Arm Brackets?) any proven aftermarket solutions?
Upper A-Arm Bracket Fix
https://www.s2ki.com/forums/index.php?showtopic=50244
3. Cooling (the engine runs really hot and the tracks i go to can have track temps of >50Deg C and ambient >34 Deg C
4. Differential - for AP1s at least
Solution - Comptech Reinforced Housing, Puddymod Diff, Inlinepro 300zx conversion, buy a spare (modMonkey)
5. Oil starvation under high-g turns.
Solution - Mugen, Toda, etc. baffled oil pan. (modMonkey)
6.
7.
Please add on with your experiences and possible ways to address these issues.
Direct form the sticky, you can prob. weave this into the top post
Saner Sway Bar install
http://forums.s2ki.com/forums/showthread.p...threadid=174999
Valve Retainer Replacement
https://www.s2ki.com/forums/index.php?showtopic=390357
Inner CV Joint Swap
https://www.s2ki.com/forums/index.php?showtopic=241367
Front LCA Bushing Failure
https://www.s2ki.com/forums/index.php?showtopic=165828
Got Blue Smoke?
https://www.s2ki.com/forums/index.ph...ic=524966&st=0
Old 05-12-2008, 10:16 PM
modMonkey's Avatar
For 2, I think you are referring to the A-arm brackets (?) They've been known to fail under repeated hard braking.
A lot more info for this and other things can be found in the sticky at the top of the page...
Old 05-12-2008, 10:38 PM
c32b's Avatar
Solution - Comptech Reinforced Housing, Puddymod Diff, Inlinepro 300zx conversion, buy a spare (modmonkey)
Solution - Mugen, Toda, etc. baffled oil pan. (modmonkey)
6.
7.
Thanks modMonkey. The sticky doesn't really specifically identify the failure points so I thought it might be helpful to create one so it will pop up on future searches
Old 05-12-2008, 10:45 PM
modMonkey's Avatar
hopefully it can be sticky'd
One other comment, you might just want to modify your original post at the top as people add comments. It'll be easier to look for the first post rather than searching through the entire thread for the most up to date one.
edit:
Inner CV Joint Swap
Got Blue Smoke?
Old 05-12-2008, 11:39 PM
c32b's Avatar
hi modMonkey, did u mean it this way? chk out my first post
Old 05-13-2008, 06:06 AM
marks_lude's Avatar
Gas starvation during high G lefts Ive heard. not sure if there is a baffle for our tanks... but half a tank or more fixes it.
This is a great thread for anyone beginning to prep a car for the track!
Old 05-13-2008, 07:26 AM
Tomatoevo's Avatar
It certainly is!!!
Old 05-13-2008, 08:53 AM
Billj747's Avatar
The Driver
Old 05-13-2008, 09:20 AM
INTJ's Avatar
Originally Posted by Billj747,May 13 2008, 08:53 AM
The Driver
And this post proves it.
Ap1 or AP2? subtle difference, I know.
Track or ovals?
Imagined or real?
Old 05-13-2008, 11:10 AM
Antonov's Avatar
The Driver
You have an 07, go have fun, beat the shit out of it, car will be fine.
Matt Scarbro
Car Talk - Non S2000
16
08-13-2014 11:37 PM
ripley5000
05-01-2012 05:00 AM
OldDogmeat
03-07-2009 01:22 AM
Ztec
06-21-2005 11:37 AM
Quick Reply: Failure points of the S on the track
