KW Clubs vs Ohlins DFV
I don't have experience with either, but I plan on going with Ohlins DFV when I do coilovers. I've emailed back and forth with somebody from Ohlins, and they were very prompt and knowledgable with their replies, which is a huge plus in my book, considering they are a pretty expensive item(not as expensive as Motons or multi-adjustable shocks). Though, there are still a few essential items to get on my list before I touch the suspension.
The front DFVs are 572 lbs/in and are the same height in the rear. You can put the Fronts on the rear and simply by a 650/700 lb spring for the fronts. You will need to crank up the damping, but if you need a spring that stuff, cranking up the damping should not concern you..
Originally Posted by sillyboybmxer' timestamp='1338394949' post='21740142
Interested in this too.....those spring rates seem soft on the ohlins but I don't know much
Originally Posted by Urge' timestamp='1338430457' post='21741879
[quote name='sillyboybmxer' timestamp='1338394949' post='21740142']
[/quote]
Yes the DFVs are more comfortable than stock with more than double the spring
Ohlins is one of the top suspension manufacturers in the world; you can find their stuff on the very top level of motorsports (F1, MotoGP, all classes of FIA, etc). I don't consider the fact that they are only single adjustable as a disadvantage for a street/track fun car. I have KW Clubsports and only use the rebound adjuster between street and track. I leave the compression alone.
In this case however, the KWs are really well dialed in for our application whereas I do not feel the Ohlins are. Well, I guess it depends if you want to be more biased towards street or track. I feel the KWs Clubsports have more appropriate spring rates for the type of use that most S2k guys are looking to do. The Ohlins have spring rates closer to the KW V3s.
There is another issue with the spring rates. The KWs have equal spring rates front and rear which is good for a car running the stock tire stagger. The stiffer front/softer rear for the Ohlins is better suited for a non-staggered tire setup. But I still think the spring rates are too soft as I'm running 12k/10k on my KW Clubsports. With those spring rates, my KWs still feel better than stock IMO when using my street setting and about on par with my track setting.
[/quote]
Yeah... there's a reason KWs and Ohlins cost what they do.
For 120 bucks you can move the fronts to the rears and buy new fronts springs and run 12/10
