Spacers in the front for a non-staggered setup
Old 11-01-2013, 06:44 PM
cookies28's Avatar
Default Spacers in the front for a non-staggered setup
Does any one have opinions if the car would under or over steer more if we added a 15mm spacer up front on a 255 square setup?
Thanks.
Old 11-02-2013, 05:37 AM
cracknut's Avatar
It sort of reduces the motion ratio so that will effectively soften the front springs a small amount.
Old 11-02-2013, 07:41 PM
robrob's Avatar
Adding 30mm of front track width should reduce lateral weight transfer and offer a little more traction so adding this effect to cracknut's softer front suspension would = more oversteer. The spacers would also add a lot of stress to the front wheel bearings and I think you'd need some major fender work to keep from rubbing the tire's outside edge.
Old 11-03-2013, 04:04 AM
cookies28's Avatar
So generally speaking, having a wider front track in an originally square setup would induce more oversteer on corner exit / throttle?
Old 11-03-2013, 04:54 AM
CKit's Avatar
I don't think it'll make an appreciable difference. The wider front track might make it less oversteery as the rear would have to rotate farther around the wider front, but honestly I don't think it'll make more difference than a few psi adjustment in the front tires can't settle.
Old 11-03-2013, 07:19 AM
JJ7
JJ7's Avatar
I'm not sure how that would be effected but "generally speaking" I think wider front track should give a sharper turn in on entry.
Old 11-03-2013, 07:57 AM
robrob's Avatar
I don't understand this.
Old 11-04-2013, 05:37 PM
cookies28's Avatar
Any one else have opinions?
Old 11-05-2013, 03:29 AM
iamxpl's Avatar
question is which are you trying to achieve? there maybe something else you can change to get the result you want? what are the reasons why you would need to run a spacer? brake clearance?
Old 11-05-2013, 07:04 AM
Mahjik's Avatar
In general, you'll be increasing the scrub radius with the spacers so all the usual things that happen with that will still be at play (a little more steering effort, some increased instability under braking, increased tramlining, etc). I don't think you'll notice any real effects from not using the same offset on the rear.
speedjunky01
08-29-2012 06:57 PM
David_T
08-22-2009 02:28 PM
Juggernaut84
01-09-2008 12:54 PM
Castor
01-30-2007 08:34 PM
dav9515
05-14-2004 04:44 PM
Quick Reply: Spacers in the front for a non-staggered setup
