Oil Cooler How-To is Up
Matt documented his Setrab oil cooler install and it's posted on my website here: http://robrobinette.com/S2000OilCooler.htm
Let me know if you have any additions/corrections.
Rob
Rob
I remember when I got oil cooler 4 years ago and everyone asked why!!!
Few things to add:
1- Make sure all lines are free this means they don’t touch the chassis of the car (or anything)
2- Make sure all lines are supported, the AN fittings are not engineered to carry weight
3- Finally if you would like to remove the stock heat exchanger you don’t need the adapter. Simply cut the stock adapter about half an inch.
Few things to add:
In a daily driving aspect would the oil cooler keep te oil to cool? Planning to keep the stock cooler in place.I track my car when I can but have been tempted to run a small cooler like shown
As long as you use an oil thermostat, either built in to the sandwich adapter or external, you'll be fine for daily use.
Another note about the AN lines - the stainless braiding is very abrasive, so keep it away from anything that you don't want chewed up. Secure the lines properly and keep them away from hoses, wiring and anything plastic. I've been using the twist-tite (or equivalent) push on barbed AN fittings with great success on a few applications. No hose clamps needed, no leaks, no abrasive stainless hose covering.
Nice work, Rob...as usual.
http://www.motoiq.com/magazine_artic...l-cooling.aspx
As Rob mentioned in his site, for a street driven car, the 200F thermostat is the one to go with.
Rob, I look at your site all the time too
The first draft of the fire system how-to is here: http://robrobinette....Suppression.htm
Another reason people use in line (as opposed to built in) oil thermostats is to install an oil temp or pressure probe on the sandwich adapter. If you forego the built in thermostat you can get an adapter with input and output ports for the oil cooler and a single probe port for oil temperature or pressure.
