SakeBomb Oil Cooler Install Review/Feedback
Originally Posted by Arro' timestamp='1465558810' post='23989866
I actually completed install on the SBG oil cooler kit this past weekend on my 2004 (AP2).
I encountered these same issues. In addition, my 19 row cooler was not level using the brackets as-shipped. Maybe the mounting point in the center is of the radiator is different from AP2 to AP1. It looks like the 25 row cooler pictured above has the same issue, it looks a little high on the right (driver) side. I got around this by drilling some extra holes in the bracket so it would sit level. As for the brace behind the bumper? I left it out, I figured the bumper itself provides adequate bracing for the front of the frame.
Oh and another thing, flame suit on, I had to drill a hole in the bottom rear corner of my CTE intake box so i could run the lines through my airbox. I know this is not ideal as they will be warm, but it's the only route I had with the lines provided. In no way do think this is a deficiancy on SBG's part. There's no way they can design for every intake on the market for this car. I believe the CTE would be in the way of any oil lines on any kit.
As a note, I did not convey or contact SBG about this. I just chalked it up to subtle differences of AP1 to AP2, and that I'm in a little time crunch for track prep later this month. So i didn't have time to deal with the resolution. I do wish the kit would have been test fitted on an AP2 though, the brace and level issues would have been obvious to the designer.
The parts are top-notch quality, I don't want this to come across as a knock on SBG. Maybe they can work on a Version "AP2.0" for future sales.
Originally Posted by Davo307' timestamp='1465586645' post='23990326
[quote name='Arro' timestamp='1465558810' post='23989866']
[/quote]
Yep! I was like, wtf, really? I hope SBG comes up with something for you Ap2s
Originally Posted by saleach' timestamp='1465403416' post='23988200
Good info. I too bought the kit but with a 15 row and did not mount it in the recommended location (bumper mount in front of wheel well) but due to continued high oil temps I purchased a 25 row and will be going to relocate it in front of the radiator. My plan is to fab up a custom bracket and mount it on the drivers side.
Hopefully sakebomb gets this figured out. I was very impressed with the kit as well as the customer service I received. I expect that they will do something and offer a workaround for AP2 applications.
What kind of power and conditions were you still running hot under? I am on the fence about which size to go with.
When sizing an oil cooler I would consider the following:
1. Are you boosted? If so, get the bigger oil cooler.
2. Are you going to be tracking it in hot weather? If so, get the bigger oil cooler.
3. Do you have a/c and/or stock radiator? If so, consider smaller oil cooler if mounting in the bumper as it's less restrictive of airflow to your coolant.
OK, so I just got through my first weekend running the oil cooler kit.
In short, It worked!!!!
I don't have data logs, and my oil temp is read from a sensor in the pan.
Before oil cooler:
75 deg ambient weather
270-280 oil temp
After oil cooler (this past weekend)
92 deg ambient weather
240-250 oil temp
Water temps always hover between 200-205 deg. I ran (4) 30 minute sessions with one 45 minute session at the end of the day, so 5 total sessions per day.
I'm running the SBG 19 row kit with 180 deg thermostat.
In conclusion, despite the hiccups with the kit installing on the AP2, it is a very effective kit. I have no special ducting for the cooler.
Before oil cooler:
270-280 oil temp
240-250 oil temp
Thought I'd bump this thread as I installed the SBG kit last night / today on my AP2. It was the 19 row Setrab and I started last night after some dinner / wine and things didn't line up at all...similar to the OP and interference with the crash bar. I got frustrated and sent SBG a nasti-gram and then went to sleep. I went back at it this morning found some spacers in the parts bag and was able to get a pretty good install with included parts/spacers and without having to modify the crash bar like the OP did.
The following are the caveats 1. Had to drill out some different holes on the passenger side bracket to line up correctly 2. Provided my own bolt for the passenger bracket. 3.If #1 or #2 were done without needing to the instructions were not great.
Overall I'm happy now, bad on me for trying to rush into the job after a work day, I sent SBG an apology. Quality of the kit seems top notch which was key to me, didn't want to be the guy blowing oil on a track due to a homemade hoses blowing during a session. Below is the pic of the tricky area for anyone that may attempt this in the future.
Hey all! Just wanted to post and update here since it looks like there was some confusion recently. Actually thought that we updated here but it looks like we didnt! We actually re-engineered the brackets and everything now fits perfectly for AP2s. All kits that have been shipping since mid-late last year have been v2 kits. Please feel free to let us know if you have questions!
__________________
SAKEBOMB GARAGE > Click here to contact Us
Check some of our most popular products for the S2000:
- Ohlins DFV Billet Lower Mount
- Rear BBK RX-8 Caliper Conversion
- Front BBK AP Competition
- Setrab Oil Cooler Kit
Also it's been awhile but I should post an update that Sake Bomb did send me version 2 brackets for the kits I had ordered for AP2's, but obviously I already had the cooler in and had modified the bar so I didn't use them, and I didn't think the lines wouldn't reach since I had shortened them, as someone mentioned above one was way too long when I had installed it with the original brackets.
Also a clarification- My understanding is that the bar I modified is a chassis stiffening bar, not a crash beam. The bumper crash beam is located at the front under the bumper cover.
lookstoomuch (03-11-2018)
I'm not logging but after the oil cooler install I installed an oil pressure gauge to keep an eye on it and it's been fine. Unfortunately since I didn't have the gauge preinstall I can't compare to what it was before.
I believe (from memory) it sits around 70-80 on cold start idle, once warm it idles around 40-50, at WOT on track warm its around 93.
