Suggestions on oil cooler size and placement
I have an AP1 with a Vortech supercharger and FMIC and plan to add an intercooler (here's the FMIC setup I am using http://www.ultimate-racing.com/Produ...chsc-fmic2.jpg) but I would like some input on the best place to add an oil cooler. The car is my daily driver but it also sees the track and autocross and I want to make sure my oil temp's don't get too high when I'm tracking in triple digit heat.
The simplest would be to mount the cooler between between the FMIC and A/C condenser but I worry my water temp's might be too high with four heat exchangers in series.
I've also considered mounting the oil cooler above the FMIC and cuttiing holes in the bumper such as these - http://www.arrows-japan.com/parts-intake2.html - but I don't know if this will allow me the space for a sufficiently large cooler.
A third solution would be mounting the cooler off to the side behind the faux brake ducts but I have plans to install brake ducting in the future.
Any advice would be extremely helpful
In my experience, you really need to duct any heat exchanger. I think you will need the brake duct inlets for brake ducting... I need them and I am NA.
There was a PWR radiator that had an integrated oil cooler in the FS section. I would probably use something such as that. Just make sure you monitor oil temps during the cooler months.
I am running a FMIC with a comptech setup and I am using a C&R radiator with built in oil cooler. It works great. Don't install it by the faux ducting, if you don't need the brake ducts now, you will very very soon. Specially with FI at the track.
Currently I don't have any oil temp numbers as I haven't seen the track since I've had my blower installed but I anticpate higher temps as all of the tracks near me see triple digit heat.
Goldenfri, with the C&R radiator/oil cooler combo did you see any adverse affects in your coolant temperature? Also, about how much boost are you running?
minboost
10-06-2003 06:25 AM
