Thought on Fortune Auto 510 for the track?
#21
ohlins r like volk te37 errone wants them cuz they too sexy and they are the most popular. but no one cared to find out that volk te37 still weight more than rpf1 when they r in the same size. The hks is like the wedsport tc, errone knows they are out there but no one really wants to give them a try. all im trying to get across is that the ohlin is a street/some times track kit. but as u just stated ur car is a track car. BC ZR,BC HR, HKS Hipermax 3 or 4, Tein mono flex and more are much better than the ohlins but u will not get that many penis points with them like the ohlins. The ohlins get better when u opt for their formula 1 custom series coils and those guys cost upward of 25k!! best bang for buck track focus coil is not the ohlin its one of those listed above or there are plenty other like jrz but these guys r pricey. hope that clears some stuff
#23
Try out the fortune auto if I'd like. They are priced couple hundreds over a be set but they are a great coil. But u want a hassle free coil that spins up the fastest lap times u can do, get a kit that u don't need to valv and spring in the next 5 weeks. Best bang for buck is hks or bc hr series. I think the cheapest ohlin is around 1700? Someone correct me on this.
#25
If I was on that tight a budget for a car being tracked, I look at the Eibach Multi-Pro R2. They come with 16kg/mm springs. Compared with the Fortune 500/510 and DFV, these are not inserts allowing for a bigger (in this case 46mm) piston. Penskes have a 52mm piston. The Ohlins TTX36 has a 36mm piston. They are double adjustable with an external reservoir. For a lowered S2000 with gas pressure shocks, the external reservoir was import enough for Honda to include them on the OEM rear shocks at stock ride height. The rear reservoirs are piggyback on the shock, the fronts come with a cute bracket to mount them. This video shows them mounted:
. They are $2700 from board sponsor Evasive: Eibach Multi-Pro R2 Evasive-Spec Exclusive - S2KI Honda S2000 Forums . While the Eibach R2s are available for many makes, I believe Evasive is the sole source for the S2k version; I think they buy them in moderately large batches. This is Evasive's thread: Eibach Multi-Pro R2 Evasive-Spec Exclusive - S2KI Honda S2000 Forums . Price is $2700 and I believe they are made in the USA as are the Fortunes.
#26
If I was on that tight a budget for a car being tracked, I look at the Eibach Multi-Pro R2. They come with 16kg/mm springs. Compared with the Fortune 500/510 and DFV, these are not inserts allowing for a bigger (in this case 46mm) piston. Penskes have a 52mm piston. The Ohlins TTX36 has a 36mm piston. They are double adjustable with an external reservoir. For a lowered S2000 with gas pressure shocks, the external reservoir was import enough for Honda to include them on the OEM rear shocks at stock ride height. The rear reservoirs are piggyback on the shock, the fronts come with a cute bracket to mount them. This video shows them mounted: https://www.youtube.com/watch?v=TXisbj2f_DM . They are $2700 from board sponsor Evasive: Eibach Multi-Pro R2 Evasive-Spec Exclusive - S2KI Honda S2000 Forums . While the Eibach R2s are available for many makes, I believe Evasive is the sole source for the S2k version; I think they buy them in moderately large batches. This is Evasive's thread: Eibach Multi-Pro R2 Evasive-Spec Exclusive - S2KI Honda S2000 Forums . Price is $2700 and I believe they are made in the USA as are the Fortunes.
#27
If you want to talk $2700 range I'm sure you're in the range of Fortune Auto's "Dreadnaught Pro 2-way" coilovers, these do have an external resevoir
http://www.fortune-auto.com/pro2way.htm
#28
These Eibachs at $2700 are almost 50% more than the base DFVs. For the same price as these Eibachs you can get DFVs custom valved to match any rate swift springs you would like. Also if you wait just a few more days we will be announcing a new product that will truly blow the Eibach Multi-Pro R2 out of the water.
***As a side note implying that the TTX36 is an inferior damper to the Penske 8300 due to the 36mm piston is very misleading as it is a twin tube design and therefor a smaller piston can actually perform much better (Also with the addition of a free piston is eliminates the downsides of a traditional twin tube design). A twin tube damper can generate the same damping force with a much smaller piston with lower gas pressure, friction and hysteresis than a much larger mono-tube design. Each design has certain trade offs but . Both are excellent dampers and either can be set up to perform phenomenally.
__________________
SAKEBOMB GARAGE > Click here to contact Us
Check some of our most popular products for the S2000:
- Ohlins DFV Billet Lower Mount
- Rear BBK RX-8 Caliper Conversion
- Front BBK AP Competition
- Setrab Oil Cooler Kit
#29
