Distance between front OEM lip and ground on AP2
Old 03-05-2011, 11:53 AM
davgoat's Avatar
Default Distance between front OEM lip and ground on AP2
I just installed a new AP2 front bumper and OEM front lip on my AP1 and installed Buddy Club coilovers at the same time The car is sitting about 4 inches from the ground to the front lip and I'm really concerned about bottom out on speed bumps and do not want to tare up the new lip. I like the lowered look but not worth it to tare up the lip. I had complete AP2 05 model OEM stock suspension on the car before installing the coilovers new bumper and lip.
What I need to know is someone with stock OEM suspension from 04-05 (maybe 06 up also) with front OEM lip the distance from ground to lip is? I rather see what someone else car sits instead of removing the coilovers and installing OEM suspension to find out. I might be going back to the stock suspension instead of raising the car more with the coilovers.
Any help is appreciated
THANKS
Old 03-05-2011, 04:55 PM
dsthez's Avatar
i dont know but why dont you just lower the car like a 1/2 inch from stock?? it will still look good. Your gunna scrape it eventually even at stock height unless your really carefull (garage queen)
Old 03-06-2011, 07:33 AM
lftolen's Avatar
THANKS
My 04 with the stock lip measures 5" from the lip to ground.
Old 03-06-2011, 08:04 AM
davgoat's Avatar
That the reason trying to find the distance and I only went I think 1 inch down now if I only go 1/2 not worth it for the coilovers I will just take them off and sell them and go back with the stock because I like the ride of the stock suspension anyway That amount a money for 1/2 inch drop not worth it to me.
Old 03-06-2011, 09:03 AM
davgoat's Avatar
Great Thanks for the info that what I needed to know
Old 03-06-2011, 10:01 AM
Stratocaster's Avatar
I would just reinstall the OEM setup. A drop on a street car is for looks only. On the track, 1/2" drop is the best for travel/ride height. Most then that and you lose the need travel, so you really need to increase the spring rates to go lower.
Old 03-06-2011, 10:50 AM
davgoat's Avatar
Yes I think your right should have talked to you first at 5 inches it still going to be close on parking lot curbs so off with the new suspension on with the old.
THANKS Jeff
gilwood
04-02-2010 09:25 PM
mlc
06-12-2008 08:29 AM
qtrung909
05-19-2008 06:36 PM
Jo2
03-29-2006 06:45 PM
Quick Reply: Distance between front OEM lip and ground on AP2
