Battery: Group 51r Vs. 51
What would happen if one decided to mount a group 51 battery which is identical to the 51R except the position of the terminals are reversed?
The Kirkland Signature (Costco) Group 51 battery is $34.49 and looks to use the same external components (case, lids for adding water) and same engraved markings on the case, as the Genuine Honda battery for the S2000, which is a 51R and sells for $74.xx at the dealer.
The Costco battery has a 3-yr full replacement (as opposed to 2-yr for the Honda) and 100 month pro-rated warranty instead of 60 months. It is also quite superior in most specs, such as cold cranking amps.
Although I've already installed the Honda battery this week, I'm wondering if it's feasible to place the Costco battery (or other Group 51) in the s2000... I figure if the cables don't reach due to the terminal reversal, one could simply place the battery the other way.
Any downsides to doing this?
Both Group 51 and 51R Batteries Work in S2000
The s2000 battery is pretty thin. I was able to flip a group 51 battery instead of using a 51R battery. The negative ground wires curves bit but not to much and it works like a champ.
So my Interstate Costco battery works just fine.
Aug 2020 - Costco now carries 51R battery
Received 1,555 Likes
Is the Costco you saw this, is it located in an agricultural area? I have seen some items (barrels of hydraulic fluid, huge can fans, etc) that are in Boise/Northern California/Oregon that are not in my neck of the woods on the western slope of the Sierras.
