Pic of clutch stop
Old 01-28-2017, 07:51 PM
Halfassjack's Avatar
Default Pic of clutch stop
Can someone post a pic of oem clutch stop that the clutch pedal hits when pushing down to floor? I've read only way to get it from honda is with floor pan. Thanks in advance.
Old 01-29-2017, 05:15 AM
Chuck S's Avatar
Received 1,133 Likes on 996 Posts
I just looked at my 2006. Nothing I could find like this. Pedal stops on suspended pedals are typically on the brackets holding the pedals.
-- Chuck
Old 01-29-2017, 05:59 AM
Rubber stopper on floor pan where clutch hits on floor pan/firewall when fully depressed.
Old 02-06-2017, 10:30 AM
waino's Avatar
The other day while replacing dash light bulbs I took a look at the stopper and although I forgot to get a picture, it's a flat piece about 1" round and maybe 1/4" thick, that sits flush up against the firewall.
It seems to be part number 46505-SA5-000, #13 in the pedal diagram in eStore:
http://estore.honda.com/honda/parts/...++23&dl=208095
Good luck!
Old 02-06-2017, 10:36 AM
Thanks for the effort but I think that is for the clutch switch. I found something that's works well but need to verify before posting as I don't want to cause anyone issues.
Old 02-06-2017, 10:38 AM
My car was missing the stop hence why I wanted to see factory piece on someone's s2000. Everything I had a chance I'm so envolved with something else I forget about it.
Old 02-06-2017, 11:14 AM
Conedodger's Avatar
I believe the part you are describing is the one circled in red. It doesn't appear to be part #13, which is the white stopper seen near the top of the pedal arm.
Old 02-06-2017, 11:42 AM
That's the one. What i used was a little taller. May cut it down a little. I will get pic of it later today or tomorrow as I know some people were looking for a replacement. Thanks for crawling under dash and getting pic.
Old 02-06-2017, 01:22 PM
jeffbrig's Avatar
I've ordered ever plastic bumper and pedal stop in the footwell parts diagrams, none of 'em fit. I was leaning towards putting a thin felt disc (furniture pad) over the hole, but I fear it would be too thick. Let us know what you've come up with - I need to do something with mine...
Old 02-06-2017, 01:48 PM
waino's Avatar
Yeah, #13 obviously is the little white button near the top of the pic. You could get the dashboard insulator for only $177 and have the stopper you need
Quick Reply: Pic of clutch stop
