10w-30 vs 5w-40
Old 11-18-2016, 11:51 AM
Xeon's Avatar
Default 10w-30 vs 5w-40
which one would be better for spirited driving and a little track use right now I have castrol edge 5-40 in my ap1 and I am wondering is that what I should be running
I live in Los Angeles and I drive at high rpm a lot of the time
Old 11-18-2016, 11:58 AM
deception9's Avatar
10w-30 over 5w-40. i personally run 0w-30. 5w-30 is A ok too. synthetic is a must. amsoil is my personal choice. others recommend motul, castrol, and mobile 1
Old 11-18-2016, 01:03 PM
S_DosMil's Avatar
Tran: What do you think lance? 40w.....50w.... lance responds :50w sounds nice. End scene. Vtec all day and shit ! Follow manufacturer specs and you'll be fine.
Old 11-18-2016, 01:40 PM
uh0h50's Avatar
Exotica 0W-40
Old 11-18-2016, 02:02 PM
Slowcrash_101's Avatar
You have to do it like in F1 cars. Use a straight 30w, pre-heat it to 174 degrees farenheit, and then inject it in the engine.
Seriously, the manual says you can use either, so it's up to you. I doubt you'll see, feel, or notice a difference according to your stated driving habits. I use 10w-40, I've used 0w-40 5w-40 10w-30 5w-30 0w-30, take it from someone that's been there. Whatever oil the car has used for most of it's life, use that, and keep using that, and make sure you change your oil when it's due. You'll never have a problem as long as you do that, other than burn oil, which AP1's do.
Old 11-18-2016, 02:55 PM
Soviet's Avatar
/end all oil threads please god
Old 11-18-2016, 03:42 PM
jyeung528's Avatar
5w40 is better. g'luck.
^AnDre^
07-23-2006 02:43 PM
BlitzSRM
09-20-2004 06:22 PM
GoblinKingX
07-13-2004 01:26 PM
gtirs
10-13-2003 11:50 AM
coolmeister
06-16-2003 11:29 PM
Quick Reply: 10w-30 vs 5w-40
