14mm 1.5 pitch self tapping bolt - S2KI Honda S2000 Forums
LinkBack Thread Tools
Old 06-14-2008, 03:36 PM   #1
rikhemi's Avatar
Default 14mm 1.5 pitch self tapping bolt
Went to a local auto store "Advanced auto parts" but they didnt have the correct size. I tried looking online but couldn't find it either. Anyone know of any places I might be able to find it locally or on the internet.
Thanks
rikhemi is offline   Reply With Quote
Old 06-14-2008, 03:42 PM   #2
sears?
a_zepeda926 is offline   Reply With Quote
Old 06-14-2008, 06:28 PM   #3
snap-on website.
matco website
McMaster carr website.
jeggy is offline   Reply With Quote
Old 06-14-2008, 08:18 PM   #4
rikhemi's Avatar
I went to 3 other autopart stores and all they seem to have is 14mm by 1.25.
Ill try sears out tomorrow. If not I'll just have to order it online.
Old 06-15-2008, 01:37 AM   #5
[QUOTE=rikhemi,Jun 14 2008, 02:36 PM]Went to a local auto store "Advanced auto parts" but they didnt have the correct size.
Sleeper2000 is offline   Reply With Quote
Old 06-15-2008, 11:35 AM   #6
Sorry, i was thinking of a tap and die set But yea a local hardware store should have it.
Old 06-15-2008, 12:15 PM   #7
rikhemi's Avatar
Just to clarify, this should be the correct size on our oil pan if the thread is stripped?
Old 06-15-2008, 12:22 PM   #8
Member
Slows2k's Avatar
14x1.5 is the original drain plug's size.
If the pan is stripped too badly a tap isn't going to fix it.
Slows2k is offline   Reply With Quote
Old 06-15-2008, 07:51 PM   #9
rikhemi's Avatar
Well went to a ace hardware which carried the taps. They advised me that I should go with the next higher size since the pan was stripped. They said a 9/16 tap with the correct plug would be sufficient since its slightly larger than 14mm. I belive its around 14.5 mm
Does this sould right. I felt it makes sene since if the oem size is 14mm x 1.5, why would you tap the same size.
Also, this is for a pt cruiser with a aluminum pan. Are there any precautions I should take to prevent it from potentially cracking. The 9/16 is barely bigger so it shouldn't cause an issue but I wasn't sure. Ive read that they sell an oversize drain plug which taps itself as its threaded. Could this be another option?
Thanks again
Old 06-16-2008, 02:00 AM   #10
[QUOTE=rikhemi,Jun 15 2008, 06:51 PM]Well went to a ace hardware which carried the taps.
Thread Thread Starter Forum Replies Last Post
Transmission / Clutch case bolts P/N merkis1024 S2000 Under The Hood 4 08-22-2014 09:15 AM
DIY Braces CHIPPO UK & Ireland S2000 Community 11 03-15-2010 05:39 AM
FS: Magnetic Drain Plug Sets marcucci Texas - North Texas S2000 Owners 10 12-28-2006 09:26 AM
Pitch of Oil Drain Bolt? Tim S2K S2000 Under The Hood 3 03-26-2002 03:43 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
