AMSOIL Oil
Thicker oil will increase the oil pressure 'cuz it's resisting flow. Flow is vital. Blackstone Labs (an oil analysis shop some of us use) published their results of using 0W-20 oil in several engines and not seeing any wear not present with 10W-30. Spec for our cars remains 10W-30.
-- Chuck
-- Chuck
Current Oil Pressure
Cold Idle: 85-90 psi
Idle at Temp: 12-20 psi
Over 3K: 72-84 psi
VTEC: 77 psi
I saw it drop to 8 psi at hot idle after driving my car around for a long period of time.
Over 3K: 72-84 psi
VTEC: 77 psi
Didn't you get your answer in your other thread? 8 to 12 at idle is low. You have two options, rebuild or thicker oil. I would go with a 15/40 and see what your pressure is with that oil. Or you could start a third thread.
ROD
p.s. I would take off the oil filter(no need to change the oil) and cut it open to see if it has any metal in it.
ROD
ROD
ROD
p.s. I just don't feel comfortable putting diesel oil in my car, something just doesn't seem right. If it works for you than kudos but I don't want to loose any sleep over it. Thanks though!
If you think a 10/40 and 10/30 are the same at cold temps take a look at Mobil Super, same goes for Mobil 1 H/M
Look at the cSt@40c 68.8 for the 10/30, 105.8 for the 10/40
This is 10/30
API Service Classification SN
Gravity, API 31.3
Specific Gravity 0.8693
Pour Point, °C (°F) -36(-33)
Flash Point, °C (°F), ASTM D 92 230(446)
Viscosity
cSt at 40°C 68.8
cSt at 100°C 10.5
CCS, cP 6,300 @ -25ºC
MRV, cP 17,000 @ -30ºC
Viscosity Index 140
and here is 10/40
Gravity, API 31.5
Specific Gravity 0.8681
Pour Point, °C (°F) -33(-27)
Flash Point, °C (°F), ASTM D 92 240(464)
Viscosity
cSt at 40°C 105.8
cSt at 100°C 15.2
CCS, cP 6740 @ -25ºC
MRV, cP 27,500 @ -30ºC
Viscosity Index 152
Also look at the Mini-Rotary Viscometer and Cold-Cranking Simulator both are higher in the 10/40 than the 10/30 and this is at -25 and -30c
ROD
This is 10/30
Gravity, API 31.3
Viscosity
cSt at 40°C 68.8
cSt at 100°C 10.5
Viscosity Index 140
and here is 10/40
Gravity, API 31.5
Viscosity
cSt at 40°C 105.8
cSt at 100°C 15.2
Viscosity Index 152
ROD
Ok, then what is the major difference in the 2? Does switching to 10W-40 adversely affect the engine in cold starts? I read that Castrol is thinner than a standard 10W-30 which is what I use currently. If I switch to say Valvoline 10W-30 could it have the same effect as switching to 10W-40?
By the way some 15/40 oils have a cSt@40c 109 and the Mobil Super 5000 10/40 I would use to see if that helped my oil pressure has 105.8@40c So you see you have to look at the numbers to know if its thick or not.
I would still open up the oil filter to see if its clean or not
Here are some picks of oil filters that came off of S's in my town
Oil Filters by Rod Rounds | Photobucket
Spread the pleats and see if you have much if any metal.
ROD
