Headlight went out, need help
Old 03-08-2011, 10:43 AM
flexctacy's Avatar
Default Headlight went out, need help
Ok, im sure this has been explained elsewhere, but, my passenger side low beam went out. I am not sure which K bulb I need for the HID. It says the most common is 6000 but I wasnt sure. I want to make sure it matches my driver side and that is stock. But what should I be looking for? DE2? How much? I've heard I may have to take off the front bumper and all this nonsense. If anyone can help, thanks, I got a 2001 S2K.
Old 03-08-2011, 01:32 PM
ed62slow's Avatar
You must remove the bumper if you are taking out the headlight. otherwise, just remove the fender liner to access the back side the the light. The lightbulb is a Philips D2S 35w
Old 03-10-2011, 12:32 AM
imnida's Avatar
What he said.
I know when i turn my lights on, one would sometimes not turn on. At first i figured it was blown, might sound weird, but i turned them off by accident (signaling) and they both turned on normally when i switched them back on. This happens to me every soo often.
Wouldn't hurt to see if your "burned out" one turns back on when you switch between on and off a few times.
1point3_to_2point2
09-16-2012 10:07 PM
S2kmonkey
03-29-2012 08:47 PM
AustinS2k2003
09-04-2003 11:05 AM
LIL RAJA
06-12-2002 07:14 PM
StevenH
10-30-2001 02:38 PM
Quick Reply: Headlight went out, need help
