Antifreeze - S2KI Honda S2000 Forums
Antifreeze
Old 03-06-2011, 05:42 PM   #1
Default Antifreeze
Ok.... 2 questions about antifreeze ...... there is the GREEN stuff that's been around for ages .... and then there is the PINK stuff. What's the difference and what goes into our S2000?
Thanks
CitadelBlue is offline   Reply With Quote
Old 03-06-2011, 07:08 PM   #2
there are actually over a dozen different types of coolant on the market.
for the S2000, stick with honda coolant.
jeggy is offline   Reply With Quote
Old 03-06-2011, 07:16 PM   #3
zeroptzero's Avatar
yeah can you get the Honda coolant ?, it's more of a blue colour. Some aftermarket fluids have silicates which aren't good for the S2K system. My OEM rad was spotless after 9 years on the Honda coolant, I wouldn't use anything else.
zeroptzero is offline   Reply With Quote
Old 03-07-2011, 05:27 AM   #4
Billman250's Avatar
Honda type2 blue is the way to go. Anything else cruds up. Especially the pink stuff. That stuff is complete garbage. I've seen it countless times over the years completely destroy cooling systems, radiators, and heater cores.
Billman250 is offline   Reply With Quote
Old 03-07-2011, 06:20 AM   #5
Stoatmaster's Avatar
Is the Nissan L250 coolant suitable? I have quite a few bottles as I had to use it on my Mitsubishi FTO, standard UK coolants would ruin the coolant system. The Nissan stuff was the right Jap spec.
Stoatmaster is offline   Reply With Quote
Old 03-07-2011, 10:42 PM   #6
the green is regular coolent
and pink/red is extended life coolent,
but go with honda coolent.
after i get another overflow tank ima have to bleed my coolent -___-
not going to enjoy it very much ):
s2cho is offline   Reply With Quote
Old 03-08-2011, 04:01 AM   #7
CarbonCrew's Avatar
I cannot find a MSDS for the L250 (although I did find some for L248), I would put almost 100% certainty that Nissan has not deviated from the Asian coolant trends of a single organic, silicate free coolant, that Toyota and Honda publically use. You should have no issues running the Nissan coolant.
CarbonCrew is offline   Reply With Quote
Old 03-08-2011, 05:46 PM   #8
what about the silicate free coolants that are safe for aluminum engines found in most auto stores? Are they ok to use?
deegaw11 is offline   Reply With Quote
Old 03-08-2011, 06:09 PM   #9
Vanishing Point's Avatar
Stick with the OEM blue Honda, the cooling system is not something to cheapen on.
Vanishing Point is offline   Reply With Quote
Old 03-08-2011, 06:16 PM   #10
Emil St-Hilaire's Avatar
What quantity is required
for a complete flush and refill ???
Emil St-Hilaire is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
FS: Maintenance Items...Oil filters, Coolant, MTF bjeong1381 Bay Area For Sale 2 09-22-2008 11:36 AM
Oil in antifreeze but not the other way around. kapil_m S2000 Under The Hood 11 04-25-2008 02:39 PM
car leaking antifreeze prodigy3006 S2000 Under The Hood 5 10-19-2007 12:44 PM
Coolant (Water & Antifreeze) mixture ratio. bitz S2000 Under The Hood 2 07-09-2005 09:19 PM
Too Much Antifreeze in Water/antifreeze mixture? supernig S2000 Under The Hood 10 03-19-2002 11:19 AM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
