Antifreeze
Old 03-08-2011, 05:25 PM
CarbonCrew's Avatar
For majority of the Asian manufacturers, a silicate free coolant is what is needed. Other salts, like phosphate, are included in the coolant packages, but due to aluminum erosion, silicate free is the critical criteria. Prestone sells a 'universal' that will probably work just fine. Would I use it and will it cause problems? No, but it isn't ideal and I'll drive to the Honda dealer for the right stuff.
If you can't make it to a Honda dealer, Valvoline has a product in it's Zerex coolant line that is specially formulated for Asian vehicles. I would have no reservations running that product.
Old 03-08-2011, 07:18 PM
jeggy's Avatar
mixing coolant in this day and age is like mixing engine oil.
will it work, yes. will the engine run, yes. should you do it, NO. why? they are different.
Old 03-08-2011, 10:58 PM
fatjoe10's Avatar
I'm using the Toyota Super Long Life (pink) in my S. Went thru the chemical data lists and they have the exact same specifications as the Honda Type 2 coolant. So far had no problems, but keeping my eye on it just in case it sludges up like some say. Time will tell.
Old 03-09-2011, 05:26 PM
Vanishing Point's Avatar
I believe, including the reservoir, the system holds 6.9 quarts.
Old 03-09-2011, 06:16 PM
Round 3's Avatar
just buy 2 gallons
Old 03-09-2011, 06:43 PM
Slows2k's Avatar
Use the Honda type 2 if you don't want to deal with clogged heater core and radiator.
Old 03-10-2011, 02:04 AM
INDYMAC's Avatar
Although this article was written a few years ago, I think it's worth reading:
http://www.gates.com/brochure.cfm?br...cation_id=2877
Personally, I use only OEM coolants spec'd for all my vehicles now.
Old 03-10-2011, 03:22 AM
zeroptzero's Avatar
Received 3,360 Likes on 2,443 Posts
If you could see the inside of my 2002 factory radiator sitting in my basement you would be hard pressed to differentiate it from a brand new radiator. It had Honda coolant in it for 8 years, I swapped it out when I bought the car 1.5 years ago. I just put in a Mishimoto rad as an upgrade.
beefystud
02-20-2015 08:30 AM
Agr07
06-30-2014 12:56 PM
Zeeb
03-03-2008 08:55 PM
THRILLR
12-03-2006 08:53 AM
superjimbo
02-25-2006 12:25 AM
Quick Reply: Antifreeze
