TPMS light on, low tire light off, tire pressures ok
Old 12-14-2012, 11:45 AM
DWynne's Avatar
Default TPMS light on, low tire light off, tire pressures ok
The low tire light came on a few weeks ago on an unusally cold morning. I aired up the tires and the light soon went out. A few days later the TPMS light comes on with NO low tire light. Bad sensor or receiver? Any way to reset the system or retrain it? Car is low mile, but is out of full warranty due to months since new. I do have a HondaCare extended warranty, but it is not clear if this is covered or not. I would like the light off and the system working as designed.
Thanks
Old 12-14-2012, 01:36 PM
Billman250's Avatar
Received 1,245 Likes on 759 Posts
TPMS light on means there is a code stored for the TPMS system, just like the CEL for the engine.
Could be many things...sensor, sensor temp, sensor battery, comm error, the list is long. you will need a TPMS scan to determine what the stored code is.
Old 12-14-2012, 06:24 PM
FISH22's Avatar
If the miles are still super low, and the bumper to bumper warranty didn't expire TOO long ago, they could possibly "good will" it. It's hard to score that, but it's not unheard of.
Old 12-15-2012, 07:52 PM
darcyw's Avatar
i'd be happy to just be sure your tires are at spec air pressure on the door jamb, check monthly as recommended, and call it a day. I've never worried about TPMS...oh wait...i rented an impreza in arizona a few years ago, tpms came on, pulled over, and sure enough, had picked up a piece of shrapnel. tire was dead in under a minute.
so just don't pick up metal and you'll be fine.
good luck
darcy
Old 01-14-2013, 09:11 AM
DWynne's Avatar
Thanks for the replies. I guess it is off to the dealer for me. I will report back with the results.
Old 01-14-2013, 01:58 PM
grkboy707's Avatar
Most of the time, TPMS is a bad sensor. Not sure what customer cost is, but it shouldnt be too bad. It does need to be reset like Billman said and most likely re-learned. Not something you can really do without the dealer
dcdomain
01-11-2013 10:54 AM
dedonderosa
05-11-2012 02:04 AM
jlammy
23
02-02-2009 12:40 PM
nightowl
10-22-2008 05:44 AM
if lookz kill
11-29-2006 04:06 PM
Quick Reply: TPMS light on, low tire light off, tire pressures ok
