Clutch clicking
Old 12-15-2009, 03:17 PM
toucansam's Avatar
Default Clutch clicking
I did a search on clutch clicking and seems to be a common issue, but none of the posts ever mentioned a fix.
Issue is when I press the clutch all the way down to floor there is a clicking that can be heard and felt with my foot. Gear engages fine. It's an 04 with 35K.
Has anyone found a solution to this issue? Or instructions on how to fix?
Thank you.
Old 12-16-2009, 03:51 AM
boofer's Avatar
search function is spotty, but i found it:
https://www.s2ki.com/forums/index.ph...ic=370792&st=0
i did that and it helped quite a bit, but every now and then, i feel a little roughness in the bottom 10% of clutch travel. however, i used plain white lithium grease instead of the shin etsu grease that others have recommended.
also, i have a slight creak coming from the 3 or 4 springs on the pedal mechanism itself (under the dash). seems like greasing those up helps a bit.
one word of caution - when you pull the slave cylinder, don't let the piston fall out. if it does, you'll have to re-assemble and then bleed the clutch before you can drive.
Old 12-16-2009, 05:19 AM
jimbosr1's Avatar
i used high temp grease last year and havent had any more issues with it sence.i also packed the grease in the slave boot and on the fork.
Old 12-16-2009, 08:02 AM
Rubn1out4GudLuk's Avatar
A friend had an issue similar to yours. He took out the slave cylinder and checked the ball. His Slave Cyl. ball got a Little pointy at one end. Sanded that part off with sandpaper to smooth out the pointed area and made sure that the ball was round and smooth again. Put some Shin Etsu grease and his clutch pedal got allot better.
Again check the little ball and make sure it's all round and has no pointy section.
JDMpearlwhyteZ
08-31-2011 05:12 PM
vtec4life57
07-26-2010 08:31 PM
02s2k01s4
06-22-2007 07:11 PM
cmn
01-18-2007 01:08 PM
GPW03
08-23-2005 04:06 PM
Quick Reply: Clutch clicking
