Clutch Bleeding Frequency
Old 10-26-2016, 02:50 PM
Rat
Rat's Avatar
Default Clutch Bleeding Frequency
How often do you bleed your clutch?
When it feels soft?
Or on a miles or time schedule?
Not talking about a full fluid change, just bleeding out the small amount of air that gets in there.
Old 10-26-2016, 03:00 PM
s2cho's Avatar
Well as long as the reservoir doesnt run dry there wont ever be any air in the line. You can just get a turkey baster and pull out the old fluid and then fill it back up with new fluid as it recirculates through the reservoir. If the pedal feels bad, or the engagement is lower than normal you can change the fluid in the res and then give the clutch a few hard pumps and it'll be back to normal.
Old 10-26-2016, 03:08 PM
redlineracing's Avatar
I do the baster thing at every OCI,5k miles.
Fluid is never dirty.
\rlr
Carolina
03 9g
03-29-2014 10:24 AM
acn684
08-16-2011 09:36 AM
kaiske
10-01-2007 03:57 AM
soundzero
03-04-2006 06:27 PM
tripleblackS2K
09-07-2004 09:33 PM
Quick Reply: Clutch Bleeding Frequency
