DIY: Bleeding the cooling system
Billmans250's procedure can be found in the following link:
https://www.s2ki.com/s2000/topic/488...t__p__10520519
Engine cold:
To start....suck on the rear pipe bleeder on the firewall (rubber cap) with a turkey baster till you get coolant. Once you get coolant to the tip, cap it off quick with the oem cap.
Make sure the rad is full.
Heat on high.
Start the engine, and hold it at 2500 till you hit 3 bars on the temp gauge. Shut it off and let it cool, you'll be able to top it off again.
Heat on high.
