Don't think turbo will happen
Might be popping it open or running inspection camera when i get back next month.
Thanks!
We have many different options available and would be happy to help you achieve your goal.
Feel free to give us a call 703-455-5805 or PM We can help get you squared away.
If you call make sure to mention you're and S2ki member as we give out discounts to s2ki.if email is better for you I have emails listed below.
Chase@inlinePro.com
Christian@inlinePro.com
Info@inlinePro.com
Chase@inlinePro.com
Info@inlinePro.com
I would do another compression check with different "high end" compression test set. Used several different tools (a bunch) and no two are the same . Also a proper leak down would be nessesary. Then bore scope. Snapon's new scope is miles ahead of older ones. Too expensive for single use but someone local will have one. I would not get in a hurry to open up a motor. Does motor still run, idle and produce power?
Chase@inlinePro.com
Info@inlinePro.com
Chase@inlinePro.com
Info@inlinePro.com
It has resulted in me considering a hone, mahle pistons, rings, rod bearings, and keeping the crank and piston rods alone.
I've, yet, to really make up my mind.
On the plus side: my brother is within a 10-20 minute drive from you guys (Manassas Park, Va).
I'd be more interested in cost if i brought it by, rather than pulling the engine and shipping it.
Oh hell yeah. It runs fine and still pulls. Just blows a good deal of smoke on vtec cross over (been like that for years).
I do not know where it sits on HP, only because it has never been on a dyno.
That was something i thought about a few times; I wouldn't ditch the original engine, though.
I've been seriously considering it. Though, the idea of cracking the engine open to put non-oem parts in it kind of scares me in the investment over longevity. Reading posts where Billman250 chimes in, doesn't leave me secure with a rebuild.
It is worth a shot with another compression test set. I'm at the point where i just want to know if that cylinder wall is scored beyond repair (if so, then sht..).
Japmuscle
08-07-2013 11:25 AM
