Driver Door Randomly Locking
Hello,
I am unsure what do to about this problem,
When I have any movement on my driver door, the door locks. I need to put the key in and keep it fully turned to open the door. If I hit unlock and then pull the handle the door locks. When I shut the door, the door locks. Locked myself in my car a few times because of this. When I get out I need to roll down the window so I can reach in while the cars running. Thoughts on how to fix this?
Thanks.
Thanks.
Weird, this happened to me a couple random times over the 13 years of ownership, one time locked me out wile the car running and I had no way to get in. Few other times the top was down and just randomly locked after I shut the door. No idea why, but hasn't been a chronic issue or id be trying to figure it out too.
If it stops the problem is isolated. Next to investigate is the internal locking module (or what ever) that will automatically lock the car 30 seconds after pressing Unlock on the remote if no door is opened.
Mine gets locked in my garage without my knowledge but I suspect I'm butt-pressing the remote in my pocket.
-- Chuck
-- Chuck
-- Chuck
-- Chuck
I find my S2000 locked in my garage all the time and I never lock the car on purpose, my keys are in the house all the time never touched between drives that are usually on weekends only for a garage queen type of use. I honestly believe a neighbour has the same frequency as my s2000 and it locks based on that. I'd say this happens a couple times per month minimum. It never happens anywhere else, just when stored in my garage.
I'm about a month into my 2003 Ap 1 and I have been noticing the full gamut of random locking events mentioned above. Reading Dr. Feelgoods recommendation is causing me to wonder if I just need to replace the batteries in the remotes? I bought a two pack, for just in case, but haven't put them in yet because the remote still seems to work without a hitch. Now I'm just going to do it to see if this weirdness stops.
The idea to remove the battery from the remote is not that a weak battery is somehow transmitting a lock signal with no button press. Rather its to verify that no one is accidentally hitting the button (lock or unloack) as keys are laying around. Maybe a button is actually being pressed, but being inside the house and out of earshot of the car locking, the person doesn't realize it.
Removing the batteries makes sure this can't happen. So if removing the remotes batteries resolves the issue, then the issue is with humans, not with the car.
