EPS & Tach/RPM Not Working...
Ok update.
Figured mine issue out. There is a wire that connects to the eps and tach which is blue. I'll look for the pin diagram and post it. It's the same wire you'd tap for an rpm signal under the passenger dash. I had this wire tapped to run RPM signal to my G2X from Racepak. It happens to have 5v of power as well. I used it to power my AIM solo and that draw of power was what caused the EPS and RPM not to work. Unplugged and it's all good. I'll be tapping the softop switch for power. epic fail avoided.
