Front Subframe lowering technique for transmission removal? - S2KI Honda S2000 Forums
LinkBack Thread Tools
Old 09-12-2011, 08:48 PM   #1
Default Front Subframe lowering technique for transmission removal?
The bolts holding the subframe to the frame will not loosen. I have tried air gun, breaker bar, and socket wrenches. Here is a pic of the instructions. The second picture is of my actual car and bolts..
the left bottom bolt is the bolt that will not budge..
jhf2005 is offline   Reply With Quote
Old 09-12-2011, 08:57 PM   #2
funkemonke's Avatar
support around the area of the bolt, use your impactool (air gun) without extension, and use penetrating oil.
gl its a big task
funkemonke is offline   Reply With Quote
Old 09-13-2011, 01:01 PM   #3
Member
Boofster's Avatar
Use a 1/2" socket with ratchet attached to a breaker bar. Looks like you're in rusty land so gl.
Boofster is offline   Reply With Quote
Old 09-13-2011, 02:22 PM   #4
I just did mine, used a 4' piece of pipe as a breaker bar and it loosened up easily. My impact wrench didn't budge them even when running at a full 150 psi. If you think these are tough, wait until you get to the top transmission bolt. That one about broke me.
Bill
03Mongoose is offline   Reply With Quote
Old 09-19-2011, 01:09 AM   #5
Member
Boofster's Avatar
^ For top transmission bolt, use 1/2" extensions with your 1/2" drive + breaker bar and won't be a problem.
It's ok to keep the reducer at the end or even an universal joint.
The issue is always too much twist in the smaller extensions.
Old 10-03-2014, 07:56 AM   #6
So there are 3 bolts holding the subframe on each side. Two of them are quite long, and the middle one is shorter. Did you remove the middle one alltogether? I backed the middle one out about 2 inches- still not enough clearance. I don't have a tall enough jack to support the subframe, so I'm afraid of taking the bolt out and having the whole thing drop on me.
igorien2k is offline   Reply With Quote
Old 10-03-2014, 09:17 AM   #7
The steady torque application of a large bar is not the best way to loosen a long fastener... a more powerful impact gun is ideal. I have found on a really tough large bolt I can up the air pressure from my normal at about 80 to 150 a difficult bolt can be removed without damage.
cdelena is offline   Reply With Quote
Old 10-03-2014, 09:37 PM   #8
Slowcrash_101's Avatar
I hope you're not trying to remove that bolt with anything less than a 1/2" drive.
Slowcrash_101 is offline   Reply With Quote
Old 10-03-2014, 10:41 PM   #9
merkis1024's Avatar
penetrating oil will definitely help. It did for me.
I also couldn't get it out with a 200 lb ft impact. returned the impact and bought a 350 lb ft milaukee and it did a little better. still returned it because i wanted to pick up a 800 lbft ingersol. lol
What worked even better is a breaker bar with a 4 foot extension. I used the metal bar used on my hydraulic jack and inserted it into my breaker bar. It came off quite easily.
merkis1024 is offline   Reply With Quote
Old 10-03-2014, 10:44 PM   #10
if there is a harbor freight store near, an you can, go grab a jack that'll reach the sub-frame.. I figure if your going to do the work, get the tools.. cause you'll use them over and over...
remove the middle two bolts completely, seriously, no worries.. the 4 corner bolts are long enough to be lowered the 3 inch drop they claim easy... and measure, don't be " about "
Ryuu is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
FL - Pfab front facing manifold turbo kit + extras S2KCHRIS305 Member S2000 Classifieds and For Sale 15 01-14-2017 12:18 PM
MGA Off Season Folly & Misadventure blueosprey90 New York - Upstate New York S2000 Owners 19 01-11-2017 06:14 PM
FS: 2002 S2000, GPW red/black interior RIDGERCR Upstate New York Classifieds 23 01-06-2017 07:02 AM
Fs: Ny --gpw ap1 $18,000 obo RIDGERCR Cars for Sale 14 01-06-2017 06:25 AM
FS: FL Pfab front facing manifold turbo kit + extras S2KCHRIS305 Florida For Sale 4 12-05-2016 07:15 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
