How long does check engine light take to reset. - S2KI Honda S2000 Forums
LinkBack Thread Tools
Old 08-27-2013, 06:53 AM   #1
acklavidian's Avatar
Default How long does check engine light take to reset.
I filled up my tank the other day and realized this morning that the check engine light is on. I freaked out for a second, but I see now that my gas cap was barely screwed on. Like not threaded at all. I tightened it down and turned on my car on only for a second because I just arrived to work, and the light was still on. How long does it usually take before the light would go off.
I know that I need to get the codes read at a parts store, but I'm stuck at work and all I can think about is my poor s2000 in the parking lot. Please someone put my mind at ease before I have a panic attack.
acklavidian is offline   Reply With Quote
Old 08-27-2013, 07:21 AM   #2
Light won't go out once a code is tripped without clearing it. You could disconnect the battery and let it sit for 15 min or so to reset it. If it comes on again, you know you have an actual problem that isn't just the gas cap. You're fine
s2kreeper is offline   Reply With Quote
Old 08-27-2013, 08:42 AM   #3
I'm new to Hondas, but in most cars, check engine lights, as long as they are resolved, will go out. You must first satisfy the monitors that the ecu requires per dtc.
If its a gas cap code you'll probably get a P1456 code.
Yes, get it checked first. It may be something a little more dire than just a loose gas cap.
You can clear your own code. There is a "clear a cel" DIY in the sticky section of this forum.
Sorry to not ease your mind.
MR.T is offline   Reply With Quote
Old 08-27-2013, 10:48 AM   #4
d-bo's Avatar
You can disconnect battery or pull the ecu//fuse (while car is off) it will clear the code but the system wont be ready for ~50 miles
d-bo is offline   Reply With Quote
Old 08-27-2013, 02:07 PM   #5
Evap is a two trip code. It will take a bit of driving but it will eventually clear itself out.
SouthDakotaS2K is offline   Reply With Quote
Old 08-28-2013, 04:39 AM   #6
iamxpl's Avatar
MY06 + we actually dont get a CEL for it. it just tells us gas cap is open. lol that would freak me out too.
iamxpl is offline   Reply With Quote
Old 08-28-2013, 05:39 AM   #7
got the same warning for the exact same reason on my 04 pilot. took about 1.5 tanks of gas to clear (450 miles roughly) without me disconnecting the battery.
ForNgoods is offline   Reply With Quote
Old 08-28-2013, 06:13 AM   #8
Southdakotas2k is right. If its an evap code, it will be a 2 cycle code to satisfy monitor criteria. It has nothing to do with mileage or time driving, but everything to do with temps, level of fuel in tank, how long the car is parked, etc..
An experienced tech can satisfy an ecu monitor in 5 minutes if he knows what the ecu is looking for.
As said before, have the codes read (though I suggest buying a cheap scan tool (20-40$) ) if it's P1456, clear it, Or just let it ride and see if it resolves itself. If its another code you'll have to dig a little deeper.
Old 09-04-2013, 06:48 AM   #9
Reset fixed it for about 500mi or so. Came on again. Its a p1457 code which is a evap valve assembly. What kind of symptoms does it cause on a running engine? I miss a few cylinders every 100mi maybe. Its rare but shouldn't happen. Does the gas cap not being tight cause extra wear on the evap assembly? What exactly does the evap assembly do?
Old 09-04-2013, 06:48 AM   #10
Thread Thread Starter Forum Replies Last Post
SRS reel replaced, horn/CC not working, help! SeanSerino S2000 Under The Hood 9 07-17-2014 11:45 AM
EVAP sensor taking forever to be "Ready" superstuddc27 S2000 Under The Hood 8 03-11-2014 06:18 PM
CEL p0411 and wiring question mfindigital S2000 Under The Hood 3 11-14-2012 07:38 PM
IAC valve clean s2konroids UK & Ireland S2000 Community 6 11-04-2007 05:42 AM
Do CELs turn themselves off ? LTB UK & Ireland S2000 Community 7 10-24-2007 07:25 AM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
