Intake whistle after air pump removal
While replacing my intake manifold that I broke a piece off of i decided to remove the air pump. I also installed Kpro since the last start up. My cold air intake has whistle to it now. Kinda like a cross between a whine and a whistle. Never had this noise before and was wondering if the air pump removal was the cause. I tried searching and reading the air pump removal threads and didn't see anything related to this.
Hard to tell from that video, do you mean the small sucking sound right after you release the throttle?
You said you removed the air pump?
What about the air valve that sits on the side of the intake manifold close to the firewall, did you cap this off?
Yes the air valve was removed and capped off with a metal plate with liquid gasket and was bolted in place. It sounds kinda like if you blew over the top of a bottle. Sound is only noticeable at idle to about 1500 rpm. Cant hear under acceleration or normal cruising.
I wonder if it could just be the CT intake and maybe you haven't noticed it before?
I had the same intake installed and think I remembered it got me wondering on some noises in the beginning, I didn't think to much about it though
