"MAP Whack" How-To
Old 01-21-2011, 12:10 PM
  #21
lilsharky's Avatar
^^anyone can chime in?
Old 01-21-2011, 02:04 PM
  #22
PWRMKR's Avatar
http://cgi.ebay.com/ebaymotors/NEW-D...Q5fAccessories
This listing (2705559236) has been removed, or this item is not available.
Please check that you've entered the correct item number
Listings that have ended 90 or more days ago will not be available for viewing.
If you think it's the MAP just get a new one from Honda.
Old 01-21-2011, 04:01 PM
  #23
lilsharky's Avatar
i dont know the part number for it..the one i found here was for 118 that comes with map sensor package??
edit: just tried the link heres the new one they put up http://cgi.ebay.com/ebaymotors/NEW-DENSO-M...=item3efe63c4ae that is $15 more!!
Old 01-30-2011, 09:04 PM
  #24
americandrug's Avatar
honda dealership would be the way to go. not saying all sources on ebay are horrid but i've had my fair share of bad parts, mostly electronics; wrong part, cracked/chipped, wouldn't work.. def get it from honda.
Old 02-04-2011, 07:05 PM
  #25
j2damilla's Avatar
When I had my is300, I ran into a similar problem which I needed to clean the MAF sensor with electronics cleaner. Could I use the same electronics cleaner to clean the MAP sensor in my AP1? It's the kind that leaves no residue.
Old 06-07-2012, 04:00 PM
  #26
Bret's Avatar
My '03 S2000 started having this intermittent hesitation when I'd get it up around 6000rpm. I thought that it might be bad gas since my car only has 7500 miles on it, but after going empty and a fill up, the problem is back. This TSB seems to describe the problem I'm having perfectly. Hopefully it's this simple. I've ordered the tie wrap and bought some electrical contact cleaner. However, my car also threw a code and I don't know what to make of it. The code is P1456 (Evaporative Emission Control System Leak Detected). Any thoughts? Is it possible that it threw the code simply because of how bad the car was shaking, but it's realy not the correct code?
Old 04-14-2015, 03:54 PM
  #27
Foxallan's Avatar
All I see is a "disclaimer" at the top of this thread... Where's the DIY portion?
Old 06-17-2015, 11:27 AM
  #28
boostinbort's Avatar
Where is all the content?
Old 10-20-2015, 08:09 AM
  #29
Wojofoo's Avatar
Where did the DIY go??
Old 10-20-2015, 03:47 PM
  #30
HotMess's Avatar
As far as i understand, the 'map whack' isn't the solution to the problem. Electrical resistivity changes from a loose MAP sensor connection are the issue. The ecu controls the engine based partially on this signal, which itself deviates from what it should be because of this loose connection. The TSB linked in the first post addresses this. A 'holder' (zip tie) holds the connection firm, preventing conductivity issues.
It seems as though i cant find the holder part from Honda anymore. I'm sure somebody could be creative with a regular zip-tie to better connect the sensor/plug. Good luck
Quick Reply: "MAP Whack" How-To
