Need some Help...Messed up bad on transmission Install
Hey guys...so im feeling a little desperate here. I started to reassemble my car after replacing my clutch on my 02 ap1. After a long time of fiddling with the transmission to get it to slide on the shaft, i started to put the 9 bolts holding the two together back in. In my tiredness, I managed to switch a longer bolt (1 of 3 that thread from the engine side, into the transmission) with a shorter bolt ( 1 of 3 that thread form the trans side, into the engine). I know this is an extremely stupid, and potentially highly costly f@#k up. I could see where the bolt had punched through the back of the block, as there were little scraps of aluminum chipped up around the bolt. Now my question is this, I really need to get this car driving again, as its my DD. I would really like to not have to pull the engine, mostly because I dont have what i need to do it, and I cannot afford someone right now to do it. I really dont know what to do at the moment. I thought about using a blob of JB weld, and some thread lock and hope for the best. (I know how dumb that sounds Any advice here would be great. Thanks guys.
http://imgur.com/z2wdKJQ
I threaded it in the hole right above the dowel pin on the drivers side from the trans into the engine.
https://i.imgur.com/0ISJ9Ri.jpg
I believe they are pretty much already punched through just not threaded from factory. I don't think you would of made it this far if you were tightening bolts and punching through aluminum.
Is there something broke off?
Yeah I can't tell from looking at pictures online if that hole goes through into the block or if it is a bellhousing for the flywheel/clutch and punched through external. If it is external then I think you should be ok. If it punched into the actual engine, you are done for.
Which one of these holes got damaged?
Thanks for the replys, I believe the hole in question, is right above the BOTTOM screw hole for the starter, on the drivers side. I punched through with a long bolt, with the bolt head facing the rear of the car. have a better picture.
