Only driving 2x/month - special maintenance?
Old 01-15-2017, 04:53 AM
Chuck S's Avatar
Received 1,128 Likes on 991 Posts
Daily driven cars are started at least twice a day and cars running in excess of 200,000 miles without excessive engine wear are the norm. Heck, my cars get started in excess of a dozen some days going to work, lunch, running errands, etc. Even the S2000. Lubrication requires oil moving and it undeniably moves slower with cold and thick. But this "wear" is of very short duration assuming a proper oil. Yeah, there's more wear but it takes laboratory instruments to measure it and it's inconsequential. Critical lubrication is at operating temperatures and the synthetic multi-grades are engineered at the proper grade at that temperature. In the spec 10W-30 the number after the W is critical, the number before can beneficial for cold starts and not affect lube at operating temperatures.
This is worth repeating: The synthetic 10W-30 grade oil is based on a heavier 30 grade oil while the mineral based 10W-30 oil is based on a thinner 10 grade oil. They are both similar at operating temperatures yet the 30 grade based synthetic is actually less thick at startup and much less honey – like at low temperatures. This is the opposite of what common sense dictates. (Bob's the Oil Guy)
Getting the car to operating temperature purges moisture, etc. There's a lot of iron and steel inside that can rust. (Pull the head off your lawn mower in the spring and verify.)
Starting or not starting is our choice. For obscure reasons I tend to follow the engineering recommendations despite knowing what idiots work in Honda engineering. I've used full synthetic 10W-30 exclusively on oil changes but there's no reason to not use 5W-30 or 0W-30 which may help in those few seconds of slow oil flow. Honda also approves 5W-40 for extreme cold.
(Sorry, too much coffee and I can't stop typing...............)
-- Chuck
Old 01-15-2017, 09:41 PM
chuhsi's Avatar
Thanks for all the help!
Yes, I do have a battery tender. I got one after my last battery was toast
boltonblue
06-06-2017 03:13 AM
EK9MAX
06-30-2010 11:32 AM
boofer
06-18-2008 06:56 AM
JiuJeetz
12-08-2006 06:01 AM
RS2000
12-03-2002 07:14 PM
Quick Reply: Only driving 2x/month - special maintenance?
