Possible Misfire?
Old 10-14-2016, 02:46 PM
RorySum's Avatar
Default Possible Misfire?
Driving into the city yesterday my temperature gauge skyrocketed, however I was stuck on the harbor bridge and there was nowhere to pull over, so it ran hot for a while.
When I finally managed to pull over I noticed a hose had disconnected from the bottom of the air intake.
I arrived at my destination, put the pipe back, and filled the rad with coolant. After that the car drove fine for a while, then it started shaking heavily while idling, and was very significantly down on power. While driving home, temps were fine, but trying to get up a big hill something happened, car lost even more power and made a noise like the engine died a little bit.
What could this be? Have I fried my car?
Old 10-14-2016, 02:49 PM
windhund116's Avatar
Received 1,424 Likes on 954 Posts
How long were you running the engine & at what temps on gauge, while on that bridge?
Check your oil dipstick for water (chocolate malt look). And radiator fluid for oil. May have popped a head gasket.
Old 10-14-2016, 02:52 PM
RorySum's Avatar
Was worried about this, and I think you might be right, engine was run hot for 3-5 minutes.
There was a bit of oil on the rad cap, time to see how much head gasket jobs are.
Old 10-14-2016, 03:02 PM
You can use a radiator pressure kit to check whether you have a leak in the coolant system.
Good luck!
https://www.youtube.com/watch?v=CHp5E7XnbXo
http://www.youtube.com/watch?v=CHp5E7XnbXo
Car Analogy
12-07-2014 07:20 AM
killa_uk
03-12-2012 03:43 AM
S2kAndTheAnt
06-18-2010 11:27 AM
124Spider
05-01-2006 03:25 PM
JP_Silver_S2K
08-13-2005 03:23 PM
Quick Reply: Possible Misfire?
