Removing bottom AC compressor bolts for oil pan removal
Old 10-30-2016, 09:07 AM
driftqueen's Avatar
Default Removing bottom AC compressor bolts for oil pan removal
Anyone know how to remove the bottom bolts on the AC compressor? I'm installing a baffled oil pan and need to remove these in order to drop the pan.... I for the life of me can't find an area where a wrench/ratchet etc fits
Old 10-30-2016, 10:01 AM
HardFlip's Avatar
Hey, I just got done swapping my clutch, and took out these bolts (although i didnt have to , the manual said to do it so i did anyway.) I used a ratchet with a swivel head and some sharp force to break the bolts loose. It wasnt easy, but you can get a socket on there if you use a swiveling ratche head.
Old 10-30-2016, 10:04 AM
HardFlip's Avatar
https://goo.gl/images/AXVQAZ
something like this. I got one from harbor freight
Old 10-30-2016, 02:01 PM
Slowcrash_101's Avatar
Condenser is in front of the radiator. Unless you're talking about the compressor. In which case this topic has been beaten to death.
Old 10-30-2016, 02:26 PM
driftqueen's Avatar
Gah yeah that's what I meant. I keep getting the 2 words mixed up
Old 10-30-2016, 02:54 PM
zeroptzero's Avatar
Received 3,361 Likes on 2,444 Posts
I do it from underneath using a ratcheting box end wrench with a flexible head, as you have to approach it on a 45 degree angle. Others have done it from above the engine bay but I haven't . I mentioned this in your other post.
Old 10-31-2016, 05:49 AM
You have to do it from underneath. I've done plenty of A/C work, and it's nearly impossible to remove the compressor from the top, I mean it might be possible, but I'm not masochistic enough to try.
Old 10-31-2016, 06:42 AM
driftqueen's Avatar
Which bolts did you remove? The ones I was told to remove are impossible to reach. I went out and bought a set of these:
http://m.harborfreight.com/hand-tools/wrenches/5-pc-metric-flex-head-combination-ratcheting-wrench-set-61710.html
And still couldn't get to them
Old 11-01-2016, 12:22 PM
Billman250's Avatar
Received 1,245 Likes on 759 Posts
There is a triangle bracket on the oil pan with 3 12mm bolt heads. Do not touch them. I can tell you are trying to, and it won't happen.
Just remove the two lower compressor bolts with 14mm heads that thread into the triangle bracket, then the pan and triangle bracket come off as one. Be sure to bolt the bracket to the new pan before installing.
TeslaChicken
09-11-2015 04:55 PM
AndyFloyd
08-14-2012 11:52 AM
shift9k
03-07-2012 01:22 PM
Sabre
07-28-2011 01:33 PM
dievoche
07-18-2010 06:09 AM
Quick Reply: Removing bottom AC compressor bolts for oil pan removal
